Ricoh MP C300 Scanner driver on Windows 10
  • gideon
    • 283
    What is the best way to connect the scanner to pc windows 10?
    Right now it can't find the pc (printing is fine).
    • 37452
    Re: Ricoh MP C300 Scanner driver on Windows 10
    Exactly what kind of scanning are you wanting to do?
    • gideon
      • 283
      This a customer that scan their document PDF, but the copier see the folders but can't communicate, their IT guy says that the scanner is not set for windows 10.
      I have no idea if the IT tried to download the updated scanner twain from Ricoh on their computer.
      • fshead
        • 2376
        i use "SCAN TO PDF" and install the twain driver and bulletproof
        • davel
          • Oct 2011
          • 1101
          Probably too old for SMB scanning, maybe try FTP.
          • Elmo
            • Feb 2010
            • 541
            There is a firmware update for this model
            I Used To Live To Fix Things Now i Fix Things To Live
            • AjitN
              • Mar 2009
              • 287
              Which exact model you r referring to?
              I have done this before and best solution is you can deactivate all security options(Like Firewall) for windows for that particular PC and try again after rebooting PC.
              So if at all this works, which means machine Firmware is not fully compatible with current version of windows(What customer is using)(What a Mess created by MICROSOFT
              firm Which is suppose to give solutions, there is no back end compability)
              If you know MICROSOFT well you will get answer.
              Just disable all security options in PC & try, it could be some other software which holds new installation(in my case it was MACFEE security software which hold back even all new updates)
              So friends this what it is..
              Hope this helps
              • AjitN
                • Mar 2009
                • 287
                what is the best way to connect the scanner to pc windows 10?
                which model r u trying from?
                • sandmanmac
                  • 3981
                  It's the second time you've asked, and It's in the title!
                    • 37452
                    Here is something to try: Scan to the document server and then use WIM to retrieve.
                    • gideon
                      • 283
                      I tried to find the updated firmware but coouldn't find one, I think that it's available only to Ricoh dealer, which I am not.
                      • sandmanmac
                        • 3981
                        Correct. So as Davel suggested, use FTP- which is non-firmware dependent and VERY reliable, or scan to email
                          • 37452
                          Think again, it is available from Ricoh-USA which their end user site. The latest network TWAIN driver is Ver. 4.37.01 Released Date: 12/18/2012. There is also a network WIA (Windows Image Acquisition) driver available.
                          • gideon
                            • 283
                            The customers' IT says that the best for him is if I would update the firmware, I can't find it on the Ricoh downloads, anyone can help me with it (send me the update)?
                              Slim GAVE you the website ( Ricoh end user ) where you can find what you asked for.
