Ricoh aficio MP4000b dirty copies and backside very dirty
  • bejoyjohn
    • Nov 2008
    • 45
    [CQ] Ricoh aficio MP4000b dirty copies and backside very dirty
    Hi
    backside of the copy very very dirty. Can see a lot of toner getting accumulated on the transfer belt and also on drum. I cleaned the drum unit but to no avail. Transfer belt seems to be not moving ,is it possible and what to do ?please help
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Ricoh aficio MP4000b dirty copies and backside very dirty
    are you using orig toner? how's the counter? maybe need parts replacement.
    Nobody is perfect..
    • Tecnicopia
      • Jun 2015
      • 31
      Transfer Belt can be clogged. The back side of xfer belt is a waste toner bottle. Open and vacuum It. Rotate by hand the belt, when they're a lot of time stopped, get sticked to the rollers.
      If this doesn't work, change the part.
      Originally posted by bejoyjohn
      Hi
      Enviado desde mi Redmi 4X mediante Tapatalk
      • 8T2
        • Aug 2015
        • 257
        I've had a few where the transfer belt drive gear has disappeared... presumably users manage to lose them while removing a jam.
        Sent from my ALE-L02 using Tapatalk
          as others have asked... life/page count on consumables?
          dirty backside can also be fuser.
          is inside clean?
          "stop test"? image or smears on belt like you see on page? what about on PCU's? ( post examples )
          again so many questions and soooo little info.
            • 37532
            This model and the 5000, its predecessors and subsequent models are well known for crappy copy quality. Ricoh has changed toner manufacturers in the past because of the problem. Quick check, look at the development roller. If the roller is coated black, not just toner that wipes off easily with a soft cloth but a film that has to be scrubbed off with a copper bristle brush or a scratchy pad. To correct it you need to first have in your possession Genuine Ricoh developer and toner.
            Dump the development unit. Scrub the costing off the roller completely. Some also recommend coating the roller with a metal polish. Now clean all toner and residue from the pcu to include the toner recycle system and the toner hopper. If there is any toner residue in the waste toner/transfer belt unit, clean it as well.
            Once all old toner is gone you're ready to put back together using Genuine Ricoh supplies and toner.
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              Having dealt with many of these I can sadly attest that this is the ONLY mostly sure way to get the machine running cleanly. Even then if the machine is underused it may well go to crap again.
              These things are the devil spawn.
              • Mark Bbb
                • Jun 2012
                • 1662
                if you replace the develoment fliters at approx. 90K, it will last longer...
                • 8T2
                  • Aug 2015
                  • 257
                  I actually really like these machines. Forgot the SP number but SP2 somewhere is P Pattern Setting. Drop that from 100 to 25 and they run like a dream even when printing small jobs
                  Provided it's up to date with PM's
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    You'd be running process control patterns 4 times as often which would consume some toner. Probably why it works better. These and the larger machines like the MP6002 really do NOT like to be underused, especially in the coverage department.
                      • 37532
                      And let them get one bottle of crap toner and your quality can go all over the ballpark. Under toned one day and over toned a couple of hours later. No matter what you do you can't fix it until you get all that toner out .
                      • FrohnB
                        • Jul 2017
                        • 1919
                        Remove transfer unit from machine. Remove Transfer belt from unit. Take out three screws that hold cover on transfer unit. Vacuum out the transfer unit waste toner. Put back together and back into machine. This should take care of toner on backside of copies/prints. If you have background on the front also, then I would do what a couple techs on here suggested, and clean the mag roller in Dev. Unit, replace developer, and while you're at it, just replace the drum and blade.
                        **Note** - If the machine has been sitting long enough, the transfer belt can stick to the rollers in transfer unit. Have not seen it on this machine, but have seen it on earlier models that have sat in our graveyard for a long time. If it is seized/stuck on the rollers, then you'll have to replace transfer belt too and clean the roller/s.
                        Omertà
                          • 37532
                          Ricoh advises against vacuuming the waste toner box. It can easily blow the waste toner full sensor.
                          • Imprestik
                            • Aug 2012
                            • 297
                            Don't you guys just use the 8200 maintenance kits when there due for PM???
                            You get everything in Kit A and B and its a 20 minute PM even if the machine is dirty
                            Surely you don't rebuild everything.......
                            • 8T2
                              • Aug 2015
                              • 257
                              Yup we rebuild over here...cutting costs I guess
