SC 572-00 on MP5502
  • MP C5502 Fan
    • Dec 2017
    • 35
    [Error Code] SC 572-00 on MP5502
    Having some issues tracking down this code. On certain screens it is 572-02 and other's it is 572-00. This occurred after two sheets of paper were found baked around the fuser roller.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: SC 572-00 on MP5502
    [ATTACH=CONFIG]40269[/ATTACH][ATTACH=CONFIG]40270[/ATTACH]
    Dirty/contaminated thermistor and pressure roller. Clean or replace thermistor and pressure roller and clean thermopile lens.
    • DRichard
      • May 2008
      • 482
      Pressure temp not reaching target.
      Either the thermopile is dirty or the center thermistor needs replacing.
      "Enjoy every sandwich."
      -- Warren Zevon
      • MP C5502 Fan
        • Dec 2017
        • 35
        We cleaned the lenses, but disassembling the fuser unit was beyond our ability, so we sent it to the technician who refurbished the unit for repair.
        We had a tech come in, but he said various motors are broken and need to be replaced and we were able to determine from the 572-02 this was a temp issue, so we assume this was not a correct diagnosis. When the error code is cleared the machine starts normally and sounds normal until it throws the code again after a short while (fuser unit cool to the touch).
        BTW any advice on selecting a competent tech?
        • mikadonovan
          • May 2008
          • 2931
          I dunno, a location would be nice. Maybe you should not have blanked your entire profile.
          NEVER ASSUME ANYTHING
          • MP C5502 Fan
            • Dec 2017
            • 35
            Not asking for a referral... just general traits, training, etc. Probably too vague to answer - but thanks for your interest.
              • 37481
              Maybe you should try correctly providing correct information. To begin with, your title says MP5502. Now the question becomes are you actually working on a Gestetner 5502 B/W, MP C5502 color or an Okidata MPS5502. If you don't fully complete your profile, how are we to know if you are located where regional climate might be factor.
              • MP C5502 Fan
                • Dec 2017
                • 35
                1. You can't edit the title (I tried) and no one asked or seemed confused.
                2. For security reasons I cannot tell you my location.
                • jonhiker
                  • 661
                  SC 572 could mean that the thermopile needs to be replaced, not just cleaned
                    • 37481
                    That's is why you have to pay attention to what you are doing when posting.
                    As for your location, If I were to say that I lived in Ridgecrest, CA, that in no way would say that I worked at China Lake Naval Weapons Center.
                    • MP C5502 Fan
                      • Dec 2017
                      • 35
                      • easymusgrove
                        • May 2017
                        • 9
                        SlimSlob .... Having a Rough Day ? Give the guy a break
                        • anothertech
                          • 1768
                          How hard would it be to call the local Ricoh dealer?
                          • farhad
                            • Apr 2020
                            • 40
                            • Dirty thermopile lenses
                            • Defective thermistor
                            • 1. Clean the thermopile lenses.
                            • 2. Replace the thermistor at the end of the pressure roller.
                              • 37481
                              SC 572 has absolutely nothing to do with the fusing unit. It is an exhaust fan error.
