MP C305 SC452
  • ABS tect
    • Sep 2013
    • 511
    MP C305 SC452
    Hey guys i am having a weird issue with these MP C305's.
    I tested everything out, made sure everything is good and functioning properly, and updated the firmware. Then, I took it apart to clean it and when i reassembled and turned it on, i am very frequently getting an SC 452 error. Sometimes this error goes away after restarting the machine but sometimes it doesn't and i am stuck with what to do.
    I have cleaned all Transfer belt metal contacts and re seated the transfer belt, switched the transfer belt with a known working one, and still no luck. Anyone know why i am getting this code?
    Here is what the manual says but i don't see why i would be getting this code multiple times across different machines. Am i putting something back wrong?
    Paper transfer belt contact motor error
    The paper transfer belt contact motor drives beyond the specified time
    during home position detection or contact operation.
     Broken harness or defective connectors
     Disconnected connector of paper transfer belt contact sensor or
    motor
     Defective paper transfer belt contact motor
     Paper transfer belt unit not installed
    1. Check and replace the harness and connectors.
    2. Replace the paper transfer belt contact motor.
    3. Reinstall the paper transfer belt unit.
    • 8144
    Re: MP C305 SC452
    Check the right door is closing fully, if not you will get SC452.
    Try holding it firmly shut, reboot & run test prints.
    • Tecnicopia
      • Jun 2015
      • 31
      Re: MP C305 SC452
      Clean the sensor under paper transfer roller.
      Check the door close hooks.
      Also sometimes caused by the fuser.
      Enviado desde mi Redmi 4X mediante Tapatalk
      • Kimi
        • Feb 2018
        • 105
        Re: MP C305 SC452
        had this before and resolve was to replace the motor.
        • ABS tect
          • Sep 2013
          • 511
          Re: MP C305 SC452
          Thanks for the replies guys...one started working again when i messed around with the paper transfer roller. I will continue to try those suggestions and troubleshoot it.
          • Tecnicopia
            • Jun 2015
            • 31
            Re: MP C305 SC452
            Keep us informated!
