RICOH MPC 6OOO FUSER:
  • ybnews
    • Oct 2008
    • 94
    My Ricoh MPC 6000 showing code SC540.
    Fuser unit is jamming. Opened up D2 cover, Turning blue D1 knob is stiff and bumpy.
    Top fuser pressure roller to the left of the fuser heat roller almost looks like that roller has a belt on it.
    Any films on inspecting/changing out fuser rollers?
    Thank you,
    Dana Lewis
    Re: RICOH MPC 6OOO FUSER:
    Thank you,
    Dana Lewis
    found this on Google:
    • NeoMatrix
      Senior Tech.
      • 3513
      RICOH MPC 6OOO FUSER: youtube;0F4xEmJ_rCg]https://www.youtube.com/watch?v=0F4xEmJ_rCg
      video:
      I could have swore the video title said "fuser replacement."
      I didn't see the fuser being replaced....
      You don't need that fuser thingy, rip out the fuser and throw it away.
      The machine still works fine (as a boat anchor, just add concrete to the void).
      I do like the guys ingenuity of using YouTube as a means to give other Techs the require info. Ten/ten...
      • Gary Bowen
        Bowdog
        • Mar 2008
        • 250
        Quite a bit of difference between a MP 6000 and MP C6000 Fuser Unit - I don't think that video would be helpful. If you don't have the manual DO NOT even attempt to tear the C6000 Fuser apart!
          • 37508
          Not only is this video for a B/W as Gary Bowen points out, I have never had to remove the entire fusing/exit drawer in order to replace the fusing.
          • luca72
            • Oct 2017
            • 1780
            Thank you,
            Dana Lewis
            for the sc540 try to reset error code procedure, for the blue knob that turns irregularly trying to control the big gear behind the fuser roller, maybe he is about to break in two ... he .... he ...
            turn the blu knob with the fuser out, and check the green gear turn to search for any cracks
            "I'll be back"
            • MIKON
              • Jul 2015
              • 188
              Sc540 is a fuser exit motor error.
              Check for a bind ie. seized bearing .broken bear .bad roller
              • luca72
                • Oct 2017
                • 1780
                Thank you,
                Dana Lewis
                I got confused about sc540! at this moment I do not have access to the manuals (I'm at home), it is true overload fuser motor or bad cleaning web motor,i dont remember well, said he sees inside like a belt (?), may have rolled out the cleaning web and rolled / tangled on the fuser roller/pressure locked(?) ...
                "I'll be back"
                  oko I goofed on the machine... but all I did was GOOGLE the issue and there were tons of videos on ricoh fusers
