ricoh mp3352 need firmware
  • mkdirs
    • Oct 2014
    • 177
    #31
    Re: ricoh mp3352 need firmware
    What size is your SD card?
    I get it i was use a 4gb sd
    Then i use a 128mb
    Thats do the jobe
    Thanks my friend for helping
    Xerotk.com
    xerox copier technician
    • copier tech
      • 8172
      #32
      Originally posted by roser72
      Hello, i have a Ricoh Mp2851 and i only have 1 language in the settings only Espanol, Does anyone know how to put or change english on it? Can you help me please the link to download the firmware language?
      Thanks in advance
      Press user tools then button & top right (from memory) you can toggle through the language options, English should be there from factory.
        • 37532
        #33
        There is an outside possibility that desired language has not been installed. In that case the language firmware will need to be installed and the desired languages selected.
        • copier tech
          • 8172
          #34
          If this is the case drop us an email.
          Firmware Update - Printer & Copier Firmware
