MPC3003 copy quality issue
  • digicor
    • Jul 2008
    • 1153
    the copy looks like something is blocking the mirrors but there is nothing, the lamp come on all the way across
    prints are steller! couldnt be more perfect
    i cant see any obstruction in the lens
    see attached
    201809061514.pdf
  • LNorris
    • Sep 2008
    • 645
    Re: MPC3003 copy quality issue
    clean mirrors with water and dry well.
      I always apply some Rain-X Anti-Fog to the mirrors.. helps keep Ozone from building up on the ( purple haze )
        see attached
        [ATTACH]40559[/ATTACH]
        looks more drum/dev related...
        is that from the ADF or bed?
        • digicor
          • Jul 2008
          • 1153
          prints are steller! couldnt be more perfect, sorry for got to post that
          • guitar9199
            • Sep 2016
            • 1100
            Are you SURE the lamp stays on the whole time? It almost looks like you might have a bad ribbon cable in your scanner, and the light cuts out at one end or the other.
            Does it do the same through the Document Feeder, or is this just copies off the glass?
            • digicor
              • Jul 2008
              • 1153
              yes it does it on the glass or doc feeder
              the lamp seems to stay on the whole time,
                • 37353
                The black band appears to be the same distance from the lead edge and you say that it does it both off the glass and the doc feeder, I would say you have a memory problem in the IPU Memory clear of the IPU might help.
                • digicor
                  • Jul 2008
                  • 1153
                  would this be in section 5xxxx?
                    • 37353
                    I think yes but have to get to an appointment so do not have time to look it up.
                    • digicor
                      • Jul 2008
                      • 1153
                      thanks ill look into it
                      • Michael Craig
                        • Dec 2016
                        • 12
                        see attached
                        Before you do anything rash, Try removing your sbu cover and clean the lense. Also make sure the SBU connections are tight.aka. unplug and re-plug.
                        • digicor
                          • Jul 2008
                          • 1153
                          I replaced the machine and will start to diagnose in the warehouse , i will post any findings
                          • digicor
                            • Jul 2008
                            • 1153
                            also , I found out a "all memory clear" was done by accident ,(yeah sure) i have the birth cert, but is this a clue?
                              sounds like someone with a lil knowledge mucked it up. At least you have the BC so now you just have to re-input those settings and start over with the diagnosis
