MPC3003 copy quality issue
  • FrohnB
    • Jul 2017
    • 1919
    #16
    Re: MPC3003 copy quality issue
    There are a few scanner settings on the Birth Cert., home position/ grayscale/ etc., might help. you'll have to re-input those regardless.
    It looks like an issue I had not too long ago, ended up replacing the LED lamp assembly. It's hard to actually see if it flickers, but replacing mine solved the issue. Easy to do too! 2 screws and a harness.
    Omertà
    • digicor
      • Jul 2008
      • 1159
      #17
      i did the re input of the scanner setting, same problem, would you happen to have a pt# for the lamp assy?
      • Zeldaman
        • Mar 2011
        • 946
        #18
        Hi there!
        I think it must be D1491721.
        Greetings...
