SC 552 AFICIO MP 5500
  • fshead
    • 2378
    #16
    Re: SC 552 AFICIO MP 5500
    Considering this is an old box I would swap out a backup fuser unit i know works.
    IF no backup,check lamps are good and in the right location...Thermisters are cheap so is UFR which can cause fuser codes..
    TRY spacers on the rear connector for fuser to make better contact with rear of copier..
    I think most of us went thru a learning phase wth these series and phantom fuser codes..............
    • MIKON
      • Jul 2015
      • 193
      #17
      If the heater lamps are not connected to the same color on the terminal strip on the rear of the fuser you will get a code. Green to green blue to blue.
      • hotmailpapa
        • Aug 2017
        • 14
        #18
        thanks i have checked and double checked. the only thing am yet to change is the thermostats which i have ordered. but what beats my mind is that the furser doesnt even turn. i mean both rollers. is that normal?
        • tsbservice
          Field tech
          • 8076
          #19
          Originally posted by davel
          Have you checked continuity with a meter.
          I have to admit that i don't know Ricohs, but assume you you didn't check continuity, atleast any machine with open thermostat/s will behave like this.
          • hotmailpapa
            • Aug 2017
            • 14
            #20
            SOLVED SOLVED
            thanks so much to everyone who jumped on my problem to offer a solution. the cuprit(s) were there thermostats.i had already ordered the three thermostats 192C X 2 and the middle one 211C. As soon as they were changed the old guy jumped back to life. I Owe you guys bottles of beer and well milk for those who dont drink beer.
            Bless up
              if the machine is in error state your motors MAY NOT MOVE. clearly a fuser related issue.. swap with known good ... reset codes.
                • 37641
                #22
                Error state has nothing to do with it. Derived from graphs in the detailed description portion of the service manual, if the temperature of the fusing unit is below 100C the main motor is not turned until the temperature reaches 200C.
                Learn how to use a service manual.
