SC 552 AFICIO MP 5500
  • hotmailpapa
    • Aug 2017
    • 14
    aficio mp 5500 keeps throwing sc 552 on startup. when i cheat the doors i realise the lamps do not come on.
    i have changed the three lamps and also the two thermistors. i am really going crazy. please help.
    Thank you.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: SC 552 AFICIO MP 5500
    Have any of the thermostats on top of the fuser jumped?
    Hit it.
    • hotmailpapa
      • Aug 2017
      • 14
      so far they are all intact.
      • davel
        • Oct 2011
        • 1108
        Have you checked continuity with a meter.
        • keithxxiii
          Just a tech
          • Nov 2014
          • 471
          We had this issue before and noticed that the connector for the whole fusing/exit assembly has a small paper that obstructs it. It was caused by a paper jam that the customer didn't remove properly.
          Aye! Cut the crap
          • hotmailpapa
            • Aug 2017
            • 14
            thanks i have checked all the connectors and theres not obstruction. the rollers do not also turn at all. no visible activitity in the fuser section.
              did you go and clear the codes in SM after replacing parts?
              • hotmailpapa
                • Aug 2017
                • 14
                I just entered service mode and restarted the machine? do i need to go further by entering numbers?
                  look in your manual... find the RESET ERROR CODE SP mode... reset... reboot unit.
                  just entering and exiting SM will not accomplish the task at hand.
                    • 37628
                    I have encountered bad connector blocks. When the fusing unit is installed, one or more pins will push back out of the block instead of making contact.
                    Also, since the error is a rear thermistor error, check the harness for that thermistor.
                    • hotmailpapa
                      • Aug 2017
                      • 14
                      i did a 5801 002 and rebooted. still nothing
                        • 37628
                        Until you identified and correct the exact cause of the problem, 5801 will not help. It may clear the code but the machine will immediately code again. When you cycle power, open the front door before you turn power back on. This will prevent the engine from starting which prevent coding again. If the code is still there, it was not cleared. Enter SP mode with the door still open and check the temperature of both thermistors. They should both be in the mid to upper 20s. If one is 0, negative or extremely high, there is a problem involving that thermistor.
                        • hotmailpapa
                          • Aug 2017
                          • 14
                          Thanks slimslob, i have opened the doors and cleared the error. screen was error free for a few seconds apparently waiting for fuser to warm up. then after about 30.40 seconds bam!! sc 552.
                          so i checked the thermistor temperature and they both alternate between 17 -19.
                          i think the main issue stems from the fact that the fuser unit does not kick in or move at all. rollers do not turn and the new lamps i replace do not light up.. any advice would be appreciated thanks everyone. am still here after so many hours.
                            • 37628
                            Both halves of the fusing connector, power supply Triacs , wire harness from PSU to connector and lamp wiring on fusing. You have an open somewhere going to the lamps.
                            • fbkhan3
                              • May 2012
                              • 421
                              Recently had the same issue with MP6500, replacement of the (IOB) Ass'y NO B2475128 was the fix and it took me a day to figure it out.
                              you can swap one if you have one on hand.
                              Note: Be careful with Dip switch setting when replaced.
                              Regard's
