Hi there
This one is a new one on me, the paper jams in the duplex tray when doing a single double sided copy although previously it worked for up to 30 copies or more.
Because it was jamming occasionally all I did was clean the feed roller just before the registration sensor before it goes back into the machine as this was what I suspected was causing the paper to slip. I have now cleaned all rollers and sensors too but it wont do a single double sided copy/print. It doesnt arrive at the sensor by the way it stops just before in the tray.
I hope im not being too facetious but please only reply if you know the machine as I dont want to try this that and the other, I really need to hear from someone who has had this problem
My own opinion is the feed rollers may need to dry thoroughly although of course they werent exactly wet when I tried the machine again.
The first thing I will do when I go back tothis job is try it to see if it starts working of course :-)
Calling all Ricoh experts out there ....please help
