Martini series >paper feed unit>unidir ball bearing gear lubrifix question
  • luca72
    • Oct 2017
    • 1691
    hello guys, about the paper feed unit of the martini series, I wanted to ask you, when you reconditioned, and changed the unidirectional bearings, what do you use to lubricate the new parts, you mount them dry? do you use oil? do you use grease? if yes, which ones?...or do you have your personal recipe? If so, which one?
    "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
  • keithxxiii
    Just a tech
    • Nov 2014
    • 468
    Re: Martini series >paper feed unit>unidir ball bearing gear lubrifix question
    I usually soak the gears on thinner to remove the developer then put them dry. But if the shaft is all worn out, i usually replace the whole unit
    Aye! Cut the crap
    • anothertech
      • 1757
      What's a Martini series?
        • 36903
        55 to 90 ppm engineering code name.
