Ricoh MP 301 SP mode
  • gliderider
    • May 2015
    • 131
    Working on an MP301. Went into SP mode and found that all SP codes are available to adjust accept SP 9xxxx codes.They were grayed out. Not sure why. Wanted to adjust fuser temp slightly. These fusers heat rolls are getting scored by thermistor buildup fairly quickly. Not sure why.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP 301 SP mode
    Fusing temp is in 1, not 9. Compatible toner is the biggest cause of caked thermistors.
    Hit it.
    • Coptech
      worker drone
      • 460
      Compatible toner is not the major reason. Our machines have always used Ricoh toner. Those rollers are crap. I am amazed how an engineering dept. takes a machine that has been made for generations and just wrecks it.
      • anothertech
        • 1760
        Yes I agree the rollers are crap, too soft. I change the roller and thermistor about every second time that I replace the drum. At least it's easy to change and does not cost too much.
