Ricoh mp c5503
  • heath03
    • Jul 2018
    • 80
    Ricoh mp c5503
    getting this image on copier. the pct was changed ran fine for a while, not streak in the same spot? could be fuser?
  • guitar9199
    • Sep 2016
    • 1100
    Re: Ricoh mp c5503
    Depending on the number of pages on the machine, the first thing I would check would be the transfer belt cleaning blade. (D2416141)
    They're rated for around 300K, so check your counters.
    • heath03
      • Jul 2018
      • 80
      Re: Ricoh mp c5503
      103,000 on the b/w / and 60,000 on color
      • guitar9199
        • Sep 2016
        • 1100
        Re: Ricoh mp c5503
        It shouldn't be the black PCU...those are rated for 400K. Same with the fuser rollers/sleeve. In order to eliminate the fuser, pull it and inspect it. If there are lines on the roller/sleeve that correspond with the marks on the pages, then you might have an early failure.
        Same with the BK Drum unit....pull and inspect for corresponding marks.
        • heath03
          • Jul 2018
          • 80
          Re: Ricoh mp c5503
          yes sir, i looked at them and all looked good. my waste catch is full and needs changed. I'm waiting on new one. i wonder if its overflow?
          • mikadonovan
            • May 2008
            • 2931
            Re: Ricoh mp c5503
            Looks like a K pcu issue to me.
            NEVER ASSUME ANYTHING
            • heath03
              • Jul 2018
              • 80
              Re: Ricoh mp c5503
              thats what I'm thinking, it only has 20k on it. we just changed it. i wonder if defective one
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                Re: Ricoh mp c5503
                could be the charge roller of the K drum
                Aye! Cut the crap
                • anothertech
                  • 1762
                  Re: Ricoh mp c5503
                  I'm with you, looks like it could be the ITB cleaning unit causing the problem.
                  • heath03
                    • Jul 2018
                    • 80
                    Re: Ricoh mp c5503
                    any suggestions on where to buy a transfer unit or anyone that rebuilds them?
                    ty for the help guys
