Clicking fused noise Ricoh mpc 5503
  • kayjaig
    • 144
    [Misc] Clicking fused noise Ricoh mpc 5503
    Hi all,
    I am working on Ricoh mpc5503. The fuser unit make clicking noise every time papers go through. But in free run it does not making that noise. Wonder what happen to it and how to fix it.
    Thanks in advance.
  • exCSER
    • Mar 2009
    • 98
    Re: Clicking fused noise Ricoh mpc 5503
    This is just a guess, but I would inspect the bearings on the fuser rollers. There is more stress on the bearings when passing paper than when they are just spinning.
    • davel
      • Oct 2011
      • 1107
      Replace fusing sleeve.
      • kayjaig
        • 144
        The fusing unit has been replaced. which tested normally in other machine.
        I heard something related to pressure adjustment. Anyone know how to do that?
        Thanks.
        • Vincent128
          • Sep 2015
          • 349
          A thin coating of Chemplex 710 in the bearing race surface will fix most all fuser bearing clicking noises.
          Bearings are nice thick(ish) steel, hot rollers are thin aluminum and will go slightly egg shaped and clatter around in the bearing race/heat sleeve/expansion ring..etc...
          Been using this stuff for years
          Amazon.com: Chemplex 710 , 5.3oz Tube, Fuser Film Grease: Electronics
          • copier tech
            • 8192
            The fuser gears have a known issue, the wear down early, the new ones are modified.
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              Originally posted by kayjaig
              Hi all,
              Thanks in advance.
              You should not be running the fusing motor output check with the fuser in the machine as you can destroy the fusing sleeve. This is stated in the manual, I've attached the manual page dealing with that. This is the same for any Ricoh machine with a sleeve style fuser.
              MPC4503 Service Manual fuser output check.pdf
              I've got a C5503 that I installed as new this april with less than 20k on it that should have the new gears according to its serial number yet it still clickety clicks away. I've got a C2004ex that does the same as well.
              • tiabobia
                • Jul 2022
                • 4
                Re: Clicking on my Ricoh SP C261SFNw (related?)
                Hello! New here to the forum. Would the clicking on my printer be related to the fuser bearing as well?
                  • 37556
                  Start a new thread in the appropriate forum for your printer model. This thread is nearly 4 years old. That make it dead and buried and makes you a grave robber.
