THIN lite "pink' lines only on color prints
  • davel
    • Oct 2011
    • 1080
    #16
    Re: THIN lite "pink' lines only on color prints
    Dirty optics will not cause lines or voids on prints only copies.
    • mikadonovan
      • May 2008
      • 2931
      #17
      Don't forget about laser optics. There are mirrors inside the LD unit, and there are the laser shields you clean with the blue stick. Foreign material on these will cause quality issues on prints.
      NEVER ASSUME ANYTHING
      • fshead
        • 2356
        #18
        ok.
        this account ghosted on me when i drove an hour to service it and i made them wait till i had another call nearby.
        I had a full color test print from service mode and saw no drop outs but stopped by another copier company where i get parts and showed it to
        their shop guy a few techs doing shop work.
        They didnt see anything in the test sheet till they put it under a bench lite that magnifies,like jewelers use.
        and then i could see faint voids in yellow.
        So I returned and yes there was some dev unit voids from clumps in dev unit.
        I cleaned up and big pieces and good to go...
        thanks all
          • 22937
          #19
          You mean a loupe? Congratulations on your success. =^..^=
            • 36871
            #20
            Probably something similar to this.
            • fshead
              • 2356
              #21
              I never heard of a loupe before this...
              maybe thrown for a loop...
              I never thought of using something like that before as i had it in mind that it was a software issue
              or some strange loose connections somewhere...
              thanks
              • fshead
                • 2356
                #22
                That is it...
                although now it reminds me of the animated light in PIXAR movies...
                t
                  thanks
                  jewelers loupe.. small magnifier that sits in eye socket
                  when i was with richo dealer we had one 13-26x mag .. was 3" tall.. used it to fine tune/ adjust color grids
                  not the one i used but...https://www.amazon.com/JARLINK-Illum...SIN=B078N34WZR
                  • NeoMatrix
                    Senior Tech.
                    • 3514
                    #24
                    That is it...
                    t
                    Luxo was the animate character.
                    FYI : Trivia
                    The Luxo short film by Pixar Studios was one of the very first full CGI animations using the cutting edge 3D Studio computer software with Kinematics. Of course 3D animation using "software" raytracing/lightshader rendering is now standard gaming "hardware" in many PC's these days.
                    Then you have the movies like Avatar with real time full CGI 3D rendering. Only those familiar with 3D graphics can truly appreciate the massive computer power required to render real time a movie like Avatar. I believe while making the movie the film crew blew up 3x $100K rendering computers, or was that during the making of Lord Of The Rings.
                    anyway... CGI 3D rendering is no surprise any more.
                    • LNorris
                      • Sep 2008
                      • 645
                      #25
                      I had a customer that was getting these voids. i fought with it for two days. come to find out, they had loaded a pcl5 driver. i loaded pcl6 and the void went away. still dont know what that was doing that. but customer was happy
                        • 22937
                        #26
                        I lucked into this Eisenbach. It came from a retired watchmaker and was well used. My friend bought a lot in an auction which included 3 or 4 of these.
                        The view is of a Canon iPF encoder strip. Here is an example of what you can see:
                        • fshead
                          • 2356
                          #27
                          [ATTACH=CONFIG]41245[/ATTACH][ATTACH=CONFIG]41246[/ATTACH]
                          Lets just hope "salesmen" dont talk Ricoh into offering that as a "default option"..
                          I can just hear all the "tech wannabe s customers" calling for service because a hair line if off by 0.0000001cms
                          • fshead
                            • 2356
                            #28
                            FYI : Trivia
                            Somedays I feel like a dinosaur as I remember 30 years ago having accounts that did animation .
                            One had me make the machine not fuse the image on clear "plastic type sheets".
                            They would do any editing and clean up and then fuse the image with chemicals.
                            When put together with other sheets they would make a animated "movie"...
                            Sorta like the old days but using a copier,not printer as these were the Analog days..........
