Ricoh mpc3002
Re: Ricoh mpc3002
I doubt that has anything to do with it.
As others have suggested, it's probably a toner supply problem This is from the MP C4000, but I'm sure it applies here too:
SC 362 TD error Cyan (VT high) - TD sensor defective. SC 362 TD error Cyan (VT high) - PCU defective. SC 362 TD error Cyan (VT high) - check harness and connections SC 362 TD error Cyan (VT high) - check hose pump and clutch
Just curious..... are the K, Y and C, M pumps interchangeable as in past models?
I had bought a few working pulls from mpc 2500/mpc3000 pn B223-3551 for use in mpc2800/c3300/c3001 etc and they did not fit.
There are 2 different size clutches.
I just started using my spc830dn machines that i gutted everything and even found out the 2 tray deck is interchangeable on the mpc3002 series.
I cant see paying $200 for a transfer belt nor a fuser roller belt assembly when i can hit the "scrap bin",which i do
keep neat,all items safely wrapped and labeled....
It takes time but saves me big money.......Comment
Re: Ricoh mpc3002
re"Just curious..... are the K, Y and C, M pumps interchangeable as in past models?
I might have read this wrong.
I think you can use a yellow pump in the black.
I think the only thing a bit different was the angle of the hose connection on the pump.
I never do these pump changes w/out my magnectic flashlite as i have big fingers and
always have issues connecting the connector..Comment
