Ricoh mpc3002
  • vicalvarez
    • Mar 2014
    • 33
    [CQ] Ricoh mpc3002
    Hey techs i have a problem light copies and i change the developer unit and Works fine one day and next day call my customer to tell me sane problem any help thanks.before this problem the machine asks for add toner normaly and the customer change it and working well but this time dont ask for toner and the quality its poor
    Enviado desde mi iPhone utilizando Tapatalk
  • Lagonda
    • Aug 2008
    • 1649
    Re: Ricoh mpc3002
    Did you put the rear end cover back on the PCDU assembly and if so is the copper bias connector there and making contact?
    • davel
      • Oct 2011
      • 1097
      Re: Ricoh mpc3002
      Is it print quality or only copies, if so clean optics. Did you do Sp 3-701 for K dev. Was it a new dev unit, PM counter for PCU?
      • vicalvarez
        • Mar 2014
        • 33
        Re: Ricoh mpc3002
        I change a new unit and do all adjustments and print and copies bad and the used unit i tested on Other machine works fine
        • Zaxxon
          • 608
          Re: Ricoh mpc3002
          M
          Not on xx02
          Please start you post with brand, model, problem.
          • Zaxxon
            • 608
            Re: Ricoh mpc3002
            Can you post a sample?
            • vicalvarez
              • Mar 2014
              • 33
              Re: Ricoh mpc3002
              Un going black tomorrow to check it
              • copier tech
                • 8131
                Re: Ricoh mpc3002
                Are you getting light copies on all colours or just one?
                • JDYAL
                  • Sep 2008
                  • 187
                  Re: Ricoh mpc3002
                  There is a TSB for this machine with this problem. Clean toner supply tube and if that doesn't work replace toner pump.
                  • fshead
                    • 2368
                    Re: Ricoh mpc3002
                    i agree these pumps are "almost" the same"clutch a bit beefier" as the mpc2800/mpc3501 pumps and i have changed a few with fairly low meters.
                    I usually check the Vt reading and if its high it is under toned,as i recall it needs to be around 2.50.
                    • vicalvarez
                      • Mar 2014
                      • 33
                      Re: Ricoh mpc3002
                      I check the black developer unit and the cooper bushing on the back of the developer unit its dirty and dont rubio very well the unit and comes the sc362 thanks
                      • sandmanmac
                        • 3979
                        Re: Ricoh mpc3002
                        I doubt that has anything to do with it.
                        As others have suggested, it's probably a toner supply problem This is from the MP C4000, but I'm sure it applies here too:
                        SC 362 TD error Cyan (VT high) - TD sensor defective.
                        SC 362 TD error Cyan (VT high) - PCU defective.
                        SC 362 TD error Cyan (VT high) - check harness and connections
                        SC 362 TD error Cyan (VT high) - check hose pump and clutch
                        Just curious..... are the K, Y and C, M pumps interchangeable as in past models?
                        • keithxxiii
                          Just a tech
                          • Nov 2014
                          • 468
                          Re: Ricoh mpc3002
                          We use to interchange the color pump units before but not the hose. Hose comes in different length
                          Aye! Cut the crap
                            • 37397
                            Re: Ricoh mpc3002
                            It is best if you replace the pump and hose as a set. If you order from Ricoh using the current part numbers, the pumps will come with the correct length hose for the color ordered.
                            • keithxxiii
                              Just a tech
                              • Nov 2014
                              • 468
                              Re: Ricoh mpc3002
                              Agree with that. Replacing them with new ones gives best results.
                              Aye! Cut the crap
