Ricoh mpc3002
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Ricoh mpc3002
    Originally posted by vicalvarez
    I check the black developer unit and the cooper bushing on the back of the developer unit its dirty and dont rubio very well the unit and comes the sc362 thanks
    Enviado desde mi iPhone utilizando Tapatalk
    SC362 The Connector is not deep enough pluged in the development unit.
    • fshead
      • 2376
      Re: Ricoh mpc3002
      Originally posted by sandmanmac
      I doubt that has anything to do with it.
      As others have suggested, it's probably a toner supply problem This is from the MP C4000, but I'm sure it applies here too:
      SC 362 TD error Cyan (VT high) - TD sensor defective.
      SC 362 TD error Cyan (VT high) - PCU defective.
      SC 362 TD error Cyan (VT high) - check harness and connections
      SC 362 TD error Cyan (VT high) - check hose pump and clutch
      Just curious..... are the K, Y and C, M pumps interchangeable as in past models?
      NO..
      I had bought a few working pulls from mpc 2500/mpc3000 pn B223-3551 for use in mpc2800/c3300/c3001 etc and they did not fit.
      There are 2 different size clutches.
      I just started using my spc830dn machines that i gutted everything and even found out the 2 tray deck is interchangeable on the mpc3002 series.
      I cant see paying $200 for a transfer belt nor a fuser roller belt assembly when i can hit the "scrap bin",which i do
      keep neat,all items safely wrapped and labeled....
      It takes time but saves me big money.......
      • fshead
        • 2376
        Re: Ricoh mpc3002
        re"Just curious..... are the K, Y and C, M pumps interchangeable as in past models?
        I might have read this wrong.
        I think you can use a yellow pump in the black.
        I think the only thing a bit different was the angle of the hose connection on the pump.
        I never do these pump changes w/out my magnectic flashlite as i have big fingers and
        always have issues connecting the connector..
