Mpc3002 configuration
  • GIUBOSS
    • 1437
    hello to everyone, I have a configuration problem, I should block the color prints on some computers that have installed w7 and w10. Thanks for your help
  • tjvincent
    • 280
    Re: Mpc3002 configuration
    Then you would set up user codes and give permissions as needed
    • ridgemill
      • Sep 2017
      • 193
      Or install a B&W printer driver instead.
      • GIUBOSS
        • 1437
        Greetings. I tried for two hours making several attempts by creating two users, one for printing only in b / w and one for color printing but it would seem harder than expected then I gave up. Thanks
          • 37641
          Hire a trained and knowledgeable Ricoh tech.
          • copier tech
            • 8235
            This should be a walk in the park.
            Install say the PCL 6 driver, then in printer properties choose advanced settings, printing defaults, then choose B/W.
            Next repeat the process (as if you were installing another printer) this time leave the settings as default (colour)
            • GIUBOSS
              • 1437
              thanks but the problem is to block some computers with codes not to print in color.
              • davel
                • Oct 2011
                • 1109
                For the restricted computers use a black & white printer driver, like MP 4002.
                • jonhiker
                  • 661
                  The way I, and many others handle this situation is to install the color driver, then set up user codes on the copier, then restrict who gets a user code for color printing.
                  The operator/ user manual will walk you through the procedure, including how to assign the codes.
                    • 37641
                    With some it is in the Security manual which can be found on the CD that comes with a new machine.
                    • keithxxiii
                      Just a tech
                      • Nov 2014
                      • 471
                      If you can download the old printer driver editor from ricoh, you can edit the driver and remove the color selection.
                      or
                      download MP4002 driver
                      or
                      set the user code authentication and limit users to print BW.
                      Aye! Cut the crap
