MP c 2003,2011,3003
  • Marwanalhajbi
    • Jul 2018
    • 72
    MP c 2003,2011,3003
    a Strange noise comes from the Fuser ( Gear crackling ) but it operates just fine??
  • guitar9199
    • Sep 2016
    • 1100
    Re: MP c 2003,2011,3003
    "Crackling"??
    Do you mean like the sound of a cellophane wrapper being handled?
    If you're hearing THAT kind of sound, it's likely you have a damaged Heat roller sleeve.
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      I'm not familiar with this model but in other brands you have to check the ball bearings of the fuser rollers too, they become dry (lose their inner lubrication) and make noises although the machine seems to work fine.
      My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        • 37652
        It is three different models: C2003, C2011, C3003.
          • 37652
          If it is a mechanical clicking noise, replace the pressure roller gear.
          • Zaxxon
            • 608
            Originally posted by guitar9199
            "Crackling"??
            Get my vote.
            Please start you post with brand, model, problem.
            • Codex
              • May 2008
              • 705
              hello
              it's a problem of many machines, the bearing inside the gear comes out a few mm and causes the "crackling" sound, had this last week on an MP 4554 and last month on a MP5054.
              Memento Audere Semper
              • copier tech
                • 8236
                Secret here is to check your PM counters this is what they are for.
                When I rebuild these fusers i'll replace the 3 gears & the sleeve if the pressure roller looks ok wont change it, but when I do change a pressure roller I always fit bearings too.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Ricoh also recommend only rebuilding fusing units twice.
                  • mikadonovan
                    • May 2008
                    • 2931
                    Of course they do. Mo money for them, and I bet an entire fuser assembly is expensive.
                    NEVER ASSUME ANYTHING
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      We only stick to the "2 refurb" rule if the machine is 3 hours away or more.
                      The costs are $1061(AUD) for a complete refurb and $1075(AUD) for a new fuser.
                      So buying a new fuser for an account that's 3 hours or more away is a no brainer.
                      Refurbs for machines in town only costs us $700.
