Missing Scanner Function
  • Lagonda
    • Aug 2008
    • 1649
    Our intrepid IT department have managed to lose the scan function on their MP C3503 and they have no idea how they did it. It's just not there, no icon on the screen, no folder in User Tools, no folder in SP mode and no sign of it in factory mode either. Even tried to clear it out of the memory with 5801-9 but it just says "Invalid Function"
    Where the hell have they put it??
  • BLADE
    former propeller tester
    • 478
    Re: Missing Scanner Function
    try switching it off/on
    • Lagonda
      • Aug 2008
      • 1649
      I know its Monday morning and we're all still trying to get over the week end and not yet running at our full potential but could you try being just a little more constructive then that!!!!!
      Even the IT numties tried that one .
      • zed255
        How'd ya manage that?
        • 1024
        Had the scanner disappear on a different recent model and it turned out to be hard drive corruption. No HDD codes and all other functions worked fine. Was weird.
          • 23006
          That's what I was going to say: on Konica Minolta products the first things you lose are Scanning, Faxing, and User Boxes when the HDD fails. Those functions are not visible anywhere when the HDD is failed or UnSet. =^..^=
          • AjitN
            • Mar 2009
            • 287
            I think Zed is correct. If HDD is disabled or inactive by any chance, scan function does not work at all. Try formatting HDD but be careful you will loose all inf. stored.
            • Lagonda
              • Aug 2008
              • 1649
              Thank you Gentlemen, some useful replies. I'll try another HDD and see what happens.
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                If the HDD does not fix it, look for the SP Mode Application Invalidation. I can't remember the exact SP though.
                Aye! Cut the crap
                • fshead
                  • 2376
                  did you lose document server too?
                  both scan and doc server need HD..
                  If not maybe it S just a "BLACK FRIDAY EVENT"
                    • 37478
                    I have d this happen before. It was an SP setting, but it's been so long I can't remember which. If you have a SMC report from before it quit working you might want to compare with the current.
                    • luca72
                      • Oct 2017
                      • 1774
                      strange problem, I also happened to me on another model, I solved with sp 801-009, try to format sp 832, or try another disk on fly
                      "I'll be back"
                      • BLADE
                        • 478
                        log into WIM and press 'undo'
                        • tufbnme
                          • 493
                          5895-001 and 002
                          • Lagonda
                            • Aug 2008
                            • 1649
                            Its Back!!
                            And tufbnme and Keithxxiii get instant glorification and elevation to the Technicians Hall of Fame!!
                            SP5895-02 did the trick.
                            I will be now holding a Court of Enquiry to find out which of the IT plonkers decided to turn that on. Water boarding may be involved.
