Just to be sure regarding package FW on a MPC3503
  • fshead
    • 2356
    HI
    The mpc3503 and mpc3003 use the same package FW "D1475519K.pkg"
    Am i correct with this going to NOP control panels??
    thanks
  • Oze
    Ricoh Fanboy
    • 1663
    Re: Just to be sure regarding package FW on a MPC3503
    Originally posted by fshead
    HI
    thanks
    19K is non sop and 19M is the SOP version.
    And yes...it's the same package for both models.
    • mincopier
      • Dec 2015
      • 290
      The "K" and "M" just refers to the versioning of the software.
      K came out September 2017
      M came out May 2018
      N Came out June 2018
      Thee is a difference between the NOP and SOP firmware so make sure you get the correct one.
        • 36898
        M came out May 2018
        And with some models, the version letter is the only difference in the file name of the module.
        • Oze
          Ricoh Fanboy
          • 1663
          Yep...my only point was that as of THIS date those are the 2 versions up on the Ricoh site.
          19K for NON SOP and 19M for SOP version
          Just to make sure he doesn't turn the machine into a toaster
            • 36898
            Oze, please note, I was replying to mincopier.
            • Oze
              Ricoh Fanboy
              • 1663
              All good Slim...
              • fshead
                • 2356
                thanks all.
                I try to double check FW as we dont need anymore "toasters"
                • mincopier
                  • Dec 2015
                  • 290
                  Here is the screen shot of the NOP firmware for the MPC3503, take note that that 19L is the most recent for the package file.
                  Here is the screen shot of the SOP firmware for the MPC3503, take not that 19N is the most recent for the package file.
                  19N is the latest for SOP
                  19L is the latest for the NOP
                  Both screen shots are from the Ricoh firmware history site as of today.
                    • 36898
                    A couple of things to remember with package firmware:
                    1. It only replaces those modules that are not at current level, firmware that is current but corrupted will not be replaced
                    2. It might not update peripherals.
                    • anothertech
                      • 1757
                      It looks like there is more than just the last letter that is different, the SOP starts with D146 and the NOP starts with D147.
                      • mincopier
                        • Dec 2015
                        • 290
                        The D146 refers to MP C3003 and D147 refers to MP C3503. Two different models but same family of machines.
                        • anothertech
                          • 1757
                          No sir, that is not the case here, review the firmware release notes, the MPC3003 and MPC3503 take the same firmware. D1465519N is the latest for SOP and D1475519L is the latest for NOP.
                            • 36898
                            No sir, that is not the case here, review the firmware release notes, the MPC3003 and MPC3503 take the same firmware. D1365519N is the latest for SOP and D1375519L is the latest for NOP.
                            Next time proof what you're typing. D136 is an MP C8002 and D137 a Pro 5100S.
                            • mincopier
                              • Dec 2015
                              • 290
                              Yes the MPC3003 and MPC3503 take the same firmware. I was pointing out in answer to the question of what looked like a confused tech stating that the D146 was SOP and the D147 was NOP. This is not the case. Both the D146 (MP C3003) and the D147 (MP C3503) can have either a normal op panel or a Smart op panel.
                              Also did you have D136 and D137 instead of D146 and D147?
