I have a dumb question regarding SP5801
  • fshead
    • 2376
    Greetings.
    I never play wth memory clear and know one should never do sp5801 001 unless a smc sheet is printed first.
    What does sp5801 002 engine reset?
    I was trying to figure which sub code resets any user codes settings and or security lock down settings.
    thanks
  • mincopier
    • Dec 2015
    • 289
    Re: I have a dumb question regarding SP5801
    Here is what I use when erasing previous users info off of a Savin/Ricoh machine.
    5846 -50 Address book initialization Clears the address book to include the user codes
    5801 -011 NCS (Network Control Service) Initializes the system defaults and interface settings (IP addresses also), the SmartNet Monitor for Admin, WebStatus Monitor settings, and the TELNET settings.
    5832 -1 HDD All Formats the HDD, does not clear User Codes, Erases the Document Server
    • fshead
      • 2376
      thanks
      on the 2nd one i think you meant
      5801-011
        • 37524
        Originally posted by fshead
        Greetings.
        thanks
        All the things you need to have from the birth certificate or SMC report when you do 5801-001 in order to get it printing correctly.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Run full music after an engine clear...I've seen it blow away line adjustment data before.
          • mincopier
            • Dec 2015
            • 289
            thanks
            5801-011
            Thanks, corrected. Had troubles formatting after a copy and paste.
            • fshead
              • 2376
              i hear you on SP5801-001 BUT i was asking on SP5801-002.
              Is the 02 as destructive wth settings?
              thanks
              • skinnyb
                • Jul 2008
                • 291
                thanks
                Yes. Pretty much the same thing. 5801-01 just does all of them at 1 time. 02 is the killer....
                Sent from my VS987 using Tapatalk
                • copier tech
                  • 8169
                  • DRichard
                    • May 2008
                    • 482
                    Greetings.
                    thanks
                    Turns out your question wasn't so dumb after all!
                    "Enjoy every sandwich."
                    -- Warren Zevon
                      • 37524
                      That might be true for a B/W but it is a whole new ball game when it comes to a color unit. It will require manual color alignment just to get it to where force line position does not fail. If you have never done one before, it can take 4 or 5 hours.
                      • copier tech
                        • 8169
                        I used to clean up & send out a lot of 2nd hand MPC2551 Models I did an all clear on every one never had any issues also on a few Metis models.
                        • Lagonda
                          • Aug 2008
                          • 1649
                          Well if you like living on the edge and are willing to live with the consequences when it all goes horribly wrong. At the moment I have two MP C'03 in the workshop that don't even know their supposed to be a photocopier just because a tech got a little over enthusiastic and thought a memory wipe would solve their problems.
                          • Gary Bowen
                            Bowdog
                            • Mar 2008
                            • 250
                            Just to confirm - what Slimslob says is true. A SP 5801-001 (Memory All Clear) WILL create a boat anchor or a glorified B&W copier out of a Colour copier if the Non Default settings are not re-input. I'm not sure what "Copier Tech" is referring to about executing SP5801 and not having any problems?
                            • Oze
                              Ricoh Fanboy
                              • Jul 2008
                              • 1663
                              Sounds like you need the panel config that we made for a tech here who likes to brick machines by loading the incorrect firmware
