MP C4503/C6003 Firmware Bug!!
  • guitar9199
    • Sep 2016
    • 1100
    [Error Code] MP C4503/C6003 Firmware Bug!!
    Just an FWI.... The v1.39 System/Copy firmware on the Ricoh TSRC website for the C4503/C6003 (SD Card-Normal Panel) has a bug in it!!! Do NOT use it!! You'll wind up with an SC878-00 error!!
    If you've already done it, download the previous version (v1.38) all by itself to a romdata folder on an SD card, and flash just that file. It's already worked on 2 machines I'm refurbishing that coded on me.
    ...Happy 2019!!
  • copier tech
    • 8215
    Re: MP C4503/C6003 Firmware Bug!!
    ...Happy 2019!!
    This interesting, this version is still available on the UK support site!
    V1.38 is included in the package file.
    • davel
      • Oct 2011
      • 1108
      Here in Oz only up to 1.37.
      • dalewb74
        • Feb 2018
        • 1167
        they had issues with package all firmware downloads, but my understanding is they have fixed the issue. i was told you could still download the individual firmware files, but that takes forever to do each one at a time.
          • 37624
          The reason I don't like package firmware is that it only replaces those modules that are not at current version level. If a firmware module has become corrupt it will not rewrite it.
          • IndependentChrisCT
            • Sep 2016
            • 19
            Thanks for mentioning the bug. I'm aware this is frowned upon, but please pm me if willing to link the latest firmware for my MP C4503 (USA).
            Currently:
            Module Name Version Part Number
            System/Copy 1.22 D1495550X
            Network Support 12.68 D1495567M
            Font EXP 1.00 D1495581
            PCL Font 1.06 D1315586A
            PS3 Font 1.12 D6205681
            animation 7.00 D1495564D
            Fax 07.00.00 D1495557M
            RemoteFax 03.00.00 D1495558F
            Printer 1.12 D1665701N
            RPCS 3.13.22 D1665703D
            PCL 1.13 D1665706J
            PDF 1.04 D1665733E
            Scanner 01.06 D1495560H
            NetworkDocBox 1.04 D1495568F
            Web Support 1.04.7 D1495561K
            Web Uapl 1.04.3 D1495562F
            Java VM v11 std 11.10.02 D1495579D
            Data Erase Onb 1.01x D3775934
            GWFCU3.8-2(WW) 08.00.00 D1495559J
            PowerSaving Sys F.20 D1495554E
            Engine 1.39:08 D1505504C
            OpePanel 1.08 D1491490J
            LANG0 1.08 D1491490J
            LANG1 1.08 D1491490J
            ADF 01.340:16 D6835550F
            Finisher 02.320:10 D6885301J
              • Sep 2016
              • 19
              I was able to update the MP C4503 today using the package update. Here are my new module versions. I couldn't find the ADF module update, does this appear to be the latest?
              System/Copy 1.38 D1495569P
              Network Support 12.77 D1495567X
              Fax 15.00.00 D1495557W
              RemoteFax 06.00.00 D1495558J
              Printer 1.20 D1665701X
              RPCS 3.13.24 D1665703F
              PCL 1.19 D1665706Q
              PDF 1.05 D1665733F
              Scanner 01.15 D1495560S
              NetworkDocBox 1.10 D1495568M
              Web Support 1.07 D1495561R
              Web Uapl 1.04.5 D1495562H
              GWFCU3.8-2(WW) 11.00.00 D1495559M
              OpePanel 1.14 D1491490Q
              LANG0 1.14 D1491490Q
              LANG1 1.14 D1491490Q
              • mikadonovan
                • May 2008
                • 2931
                As of 2-15-19:
                JAVA 1.12.00
                PCL 1.20
                NETWORK SUPPORT 12.78
                SCANNER 1.16
                SYS/COPY 1.40
                WEB SUPPORT 1.08
                NEVER ASSUME ANYTHING
                  • 37624
                  PCL 1.19 D1665706Q
                  PDF 1.05 D1665733F
                  ADF and SPDF are optional peripherals. They are not included in the package firmware. Another reason I always down the latest module firmware.
