MP c03 vs 04
  • Timmytronic
    • Oct 2010
    • 249
    MP c03 vs 04
  • semi
    • Sep 2008
    • 193
    Re: MP c03 vs 04
    Wait for the new model..........MF3
    • Timmytronic
      • Oct 2010
      • 249
      Re: MP c03 vs 04
      MF3? Is that correct? Can you elaborate? Thanks.
      • semi
        • Sep 2008
        • 193
        Re: MP c03 vs 04
        RICOH IM C6000/C5500/C4500/C3500/C3000/C2500 / デジタルフルカラー複合機 | リコー
        • copier tech
          • 8141
          • copier tech
            • 8141
            Re: MP c03 vs 04
            Whats this? Ricoh are reusing old model numbers? surely the next series would be xx05 !?
            • anothertech
              • 1766
              Re: MP c03 vs 04
              is the xx04 pcu a direct fit to the xx03 machine? or do I have to modify the pcu to work? I'm all for saving money on pcu's.
              • copier tech
                • 8141
                Re: MP c03 vs 04
                Yes a direct fit black xx04 fits as colour in xx03
                • Klydon
                  • Mar 2009
                  • 243
                  Re: MP c03 vs 04
                  I think the 4 is a good upgrade of the 3 series. There was a lot of new stuff tried and done with the 3 series and while a lot of it worked, a lot of it didn't. There have been a ton of bulletins applied to the 3 series along with tons and tons of firmware updates.
                  Think of a 4 series along the lines of machine that has "corrected many of the mistakes made with the 3 series with some experience thrown in". In addition, the 4 series also has some more features as people have mentioned over the 3 series and the SOP is far more better integrated on this model than it ever was on a 3 series.
                  I disagree that 2 series were better than 3 series. Maybe in the early days when the 3 series first came out and there were issues, but in general, if you have a pile of 3 series vs a pile of 2 series, you should be a lot less busy with the 3 series. The 2 series is the ultimate version of what started with the 0 series. They all used the same basic drum units and mechanically the machines were pretty much the same with a few twists here and there. Drum life on 2 series is nowhere in the ball park of a 3 series and neither is fixing film or even transport belts. I had a major customer that had an entire fleet of 3300's. I knew those machines forwards and backwards. They ran good for the most part and were fairly simple to understand. The customer upgraded to 3003's. The issue I find with 3003 is they can have some really funky issues that can be difficult to figure out, but if you get them running right, they blow away 3300's and 3002's for that matter. (I have another large customer that has a lot of 3502's. Weather turned cold and so it is time to replace drums like crazy and of course I go through fixing films a lot more often on those machines). 3003 can also be very fickle and if you have one kicking your butt, it is hard to get it to behave right compared to earlier machines.
                  Just my overblown nickels worth.
                  • ricmartinho
                    • 142
                    Re: MP c03 vs 04
                    They are reusing just the numbers! The Models change from MP and SP to IM (Intelligent MFP) and IP (Intelligent Printer).
                    The IM C2000 to IM C6000 Series is a colour MFP series for the Office segment. This is the first model in our Intelligent MFP (IM) series, and introduces the Always Current Technology concept.
                    The series is available in 13 different models, with print speeds ranging from 20 to 60 ppm and a choice between an ARDF or SPDF.
                    Model name / Design name / Design code
                    IM C2000(A) / Metis-MF3y / D0BJ
                    IM C2500(A) / Metis-MF3z / D0BK
                    IM C3000(A) / Metis-MF3a / D0BL
                    IM C3500(A) / Metis-MF3b / D0BM
                    IM C4500(A) / Metis-MF3c / D0BN
                    IM C5500(A) / Metis-MF3d / D0BP
                    IM C6000 / Metis-MF3e / D0BQ
                    • copier tech
                      • 8141
                      Re: MP c03 vs 04
                      Thanks, but MP/C has been used for many years, SP/C has always been small desktop MFPs?
                      • ricmartinho
                        • 142
                        Re: MP c03 vs 04
                        ON TOPIC:
                        Originally posted by Timmytronic
                        Hiya folks. I was wondering what the general opinion of the MP c4504 / 5504 etc family is compared to the MP c4503 / 5503 family is. I have a few 03 models and that need upgrading due to time at the customers. Didn’t know if these were a good option or stick with 03’s. I always thought the 02’s were better than the 03’s anyway. Used less toner and no transfer belt issues as I use to have unless I cleaned the sensors every 50k. Also I find the 03’s not as well built.
                        Many feed back on the 04’s would be great.
                        Happy weekend.
                        Tim b
                        We have been installing 04 for the past year or so, and so far I can't recall a major problem with them. The 03 series' Fusers are a little pain in the ass when you have prints with some coverage. The sheets get stuck to fuser belt, and there are a few bulletins for Fusing offset problems.
                        OFFTOPIC
                        Generally saying MFP was for Multifunctional machine and SP was for printer (no copier function)
                        Here is a brief history of some model names
                        A3 Office Colour MFP
                        2004 -> Aficio 2228C (Jupiter C1k | B190)
                        2005 -> Aficio 3228C (Jupiter C2k | B202)
                        2006 -> Aficio MP C2500 (Athena C1a | B230)
                        2008 -> Aficio MP C2800 (Athena C2a | D023)
                        2010 -> Aficio MP C3001 (Athena C2.5a | D086)
                        2012 -> Aficio MP C3002 (Athena C3a | D111)
                        2013 -> MP C3003 (Metis C1a | D146)
                        2016 -> MP C3004 (Metis C2a | D238)
                        2017 -> MP C3004ex (Metis C2.1a | D0AC)
                        A3 Office BW Printer
                        2003 -> Aficio CL7000 (Jupiter P2 | G080)
                        2004 -> Aficio CL7100 (Jupiter-P3c | G106)
                        2005 -> Aficio CL7300 (Jupiter P4c | G131)
                        2006 -> Aficio SP C811DN (Apollon P1d | G133)
                        2009 -> Aficio SP C821DN (Apollon P2d | G189)
                        2012 -> Aficio SP C831DN (Apollon P3d | M125)
                        2016 -> SP C842DN (Metis P2b | M0AL)
