MP C3000 right side door won't close
  • Arkynsaw
    • Oct 2017
    • 54
    I went out to install a black toner pump , easy enough . This is a new customer , had not serviced there unit before , someone else had diagnosed the toner pump and the customer had ordered it . In finishing I attempted to close the right side door , it would not close , it was closed when I arrived and I had tested the machine to see it was mostly operating , just needed the pump . The rear side would latch , but not the front side , it had lots of resistance , seemed like more resistance than I would expect , but I have only seen a few of these models . I examined the hardware , the topmost guide of the transport Z-section was broken at the rear shoulder screw , the front most hold handle on the fuser was cracked a bit , but all there . No other damage noted . If I removed the fuser unit , the right side door would close easily , both front and rear latches engaged . I saw no problem in how the fuser inserted and locked down . Pulled the fuser cover and looked at the innards , seemed fine , but I have never rebuilt this fuser or had issues with this fuser in this model . I have most of the service documentation , but no service bulletins .
    Thanks in advance , Ark .
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: MP C3000 right side door won't close
    You have a broken transfer case my friend.
    Tends to be the main reason for not being able to close the duplex door.
    Tell the customer not to force the door or your job will be made more difficult.
    Parts and labor it's only around a $150 repair.
    • keithxxiii
      Just a tech
      • Nov 2014
      • 468
      Also check the positioning guide front and rear. It usually gets broken together with the transfer assy.
      B223 6311 and B223 6312
      Aye! Cut the crap
      • Lagonda
        • Aug 2008
        • 1650
        Also check the door mounting hinge points on the copier frame. I've seen over enthusiastic clients manage to bend those.
