Ricoh MPC6003 Copy Quality
  • davez@copysystemspa.com
    • Feb 2018
    • 28
    Machine is spewing yellow toner and developer on the transfer Belt. So far have replaced Yellow PCU to no avail. Any suggestions?
  • Lagonda
    • Aug 2008
    • 1649
    Re: Ricoh MPC6003 Copy Quality
    Check several problems down the page, may be the answer to your problem
    Yellow blotches from a MP C3003 revisited
      • 37488
      As a general rule, once a machine starts sucking developer, you need to replace the developer. You may have to replace the entire development unit.
      • Dan G
        • Nov 2014
        • 56
        i'm told silver roller in transfer unit above yellow pcu can lock up or stick causing this. check and clean it?
        • Zaxxon
          • 608
          Dev.unit.
          Please start you post with brand, model, problem.
          • copier tech
            • 8144
            Can you give us some PM & main counters please?
            Check the main dust filter on the LHS of the machine, if this gets blocked will cause this issue.
            • Orion2010
              • Jun 2015
              • 176
              Replace dev.unit
