5300DN JAVA INSTALL
  • mikadonovan
    • May 2008
    • 2931
    5300DN JAVA INSTALL
    Hi, All. I am attempting to update java on this little printer with no success. I have downloaded the java file, unpacked and attempted to run the "update to xxx" file. I get the cmd line window, then I input the correct drive on my PC where my card is at, "F" in this case. THEN it says cant find the piecemark (I don't even know what that is)./ SO, I see there is a piecemark finder located within the java files. I attempt to run it and the program crashes. WTF. Can anyone shed some light on this malfunction? I have updated Java on other equipment with no issues. This should be easy.
    NEVER ASSUME ANYTHING
  • guitar9199
    • Sep 2016
    • 1100
    Re: 5300DN JAVA INSTALL
    I think "Piecemark" error means you're using the wrong Update Tool. Make sure you've got the right one for the model you're updating.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      • anothertech
        • 1768
        What card are you using for your F drive? is it a VM scard from the 5300DN?
        • copier tech
          • 8142
          Out of interest why are you updating JAVA? do you have a specific fault?
          • keithxxiii
            Just a tech
            • Nov 2014
            • 468
            Is M5005752E_upd the version you were trying to install?
            Aye! Cut the crap
            • mikadonovan
              • May 2008
              • 2931
              It is the version that came with the 5300 firmware.
              • mikadonovan
                • May 2008
                • 2931
                Negative, no VM card. However, the manual states a formatted sd card can be used, which is what I did.
                • mikadonovan
                  • May 2008
                  • 2931
                  No, just a new install. I do all the firmware stuff on new equipment before it leaves the shop. It saves me from doing it in the field later.
                  • mikadonovan
                    • May 2008
                    • 2931
                    This.
                    • copier tech
                      • 8142
                      OK, you need to be updating firmware not Java!
                      • anothertech
                        • 1768
                        The way I'm reading the manual, it says that you need to update the VM card. Here's what the service manual says...
                        For the SP5300/5310 series, updating Java VM is performed with PC using the update tool.
                         Prepare the following items in advance.
                         SD memory card reader/writer
                         PC
                         Updating flow is as follows.
                        1. Deactivate the SDK applications with Web Image Monitor.
                        2. Remove the VM CARD Type P8 from the main machine.
                        3. Update Java VM with PC using the update tool.
                        4. Install the VM CARD Type P8 to the main machine.
                        5. Activate the SDK applications with Web Image Monitor
                        • mikadonovan
                          • May 2008
                          • 2931
                          Ok, after reading the Ricoh version upgrade tools document, I am pretty sure I was using the wrong tool to do it. I appreciate all the responses. The printer will go out as is. I don't believe Java will come in to play in the environment it is being placed at. Everyone have a great weekend!
                          • keithxxiii
                            Just a tech
                            • Nov 2014
                            • 468
                            Simply disable if you won't be needing it. Java reduces the boot time of MFP devices.
                            Aye! Cut the crap
