RICOH MPC 2051 error code SC670 - [SOLVED]
+ More Options
Posts
  • luca72
    • Oct 2017
    • 1778
    hello, I wanted to share with all of you the following action in the field, this mpc2051 to restart from standby generated the code sc670, replaced the IPU card (D1055720 in Italy) problem solved, probably was damaged in transport by supporting the forklift from behind must have flexed the block cards breaking some micro-welding (I noticed parts of the sheet slightly bent inside), I hope someone can be useful this feedback ... best regards
    "I'll be back"
  • GIUBOSS
    • 1435
    Re: RICOH MPC 2051 error code SC670 - [SOLVED]
    I had solved it by formatting the hhd or resetting the controller board.
    • luca72
      • Oct 2017
      • 1778
      tried, it did not work, I also tried to leave the hdd off .. if I touched the cards slightly gave the code
      the action was dictated by an operational choice: the customer is rather inconvenient to reach, is in the center of Milan, parking is almost impossible, the 2051 we had brought 3 days before, and I would not have trusted much of a reset anyway if in this case it worked, then the MF is in turn under warranty by those who have provided it that probably will replace the ipu or we will make an important discount on the next purchase, luckily the ipu we had it!
      "I'll be back"
