SC 670-01 MPC 3503
  • JDYAL
    • Sep 2008
    • 186
    SC 670-01 MPC 3503
    Ok so I have an sc 670-01 which only happens when coming out of power saving. These are the things I have done so far. I do have the TSB for this but I'm not convinced replacing all the boards is the answer....hence why I'm posting. The machine has the smart op m3 control panel. I have updated the firmware for the panel to version 1.53 which is the latest. I have updated all machine firmware. Before I updated the firmware the machine would not even come out of power saving and the data light would not flash. Since updating it will come out of power saving but then gives sc 670-01. Has anyone seen this or have any insight that could be helpful. Any help is much appreciated
    • 8125
    Re: SC 670-01 MPC 3503
    Been fighting a few of the Metis with SC670 over the years.
    Here's the steps I take in this order.
    (1) Update ALL firmware
    (2) Set SP 5-191 to 0 & SP5730 to 0
    (3) Replace USB OP cable as per bulletin
    (4) Replace controller board
    • JDYAL
      • Sep 2008
      • 186
      Thanks for the info. Firmware is good I will try the two sp tomorrow. I have a controller board so I will also take that. Cables have been checked but I will replace them. On sp 5730 do I set all -001-002 and -10 to 0 ?
        • 8125
        SP570 disables Java I was advised to tray this by another tech machine boots up faster also.
        • JDYAL
          • Sep 2008
          • 186
          I will give it a shot today and see what happens. I'll keep you posted. Thanks
          • JDYAL
            • Sep 2008
            • 186
            So here's the update. Replaced cables= still got sc 670. Replaced controller same code. Replaced BCU board and no codes in two days. Fingers crossed hopefully that was the problem. Thanks for the help.
              • 8125
              Thanks for the update, I will add that to my list of possible causes!
