Ricoh mpc2003 + sr3130 = jam r1+r2 + sc724!
  • luca72
    • Oct 2017
    • 1778
    #16
    Re: Ricoh mpc2003 + sr3130 = jam r1+r2 + sc724!
    I can't find the specs for SR 3130 but I do believe that 50 to 60 is more than an internal finisher is designed to be able to staple.
    hello, the error code is not there anymore, but instead of stapling at the top, pinch 4 cm lower (?) look at the photo attached to the previous post
    "I'll be back"
    • luca72
      • Oct 2017
      • 1778
      #17
      Originally posted by Mark Bbb
      is this finisher the original c2003 on this machine or was this finisher original installed on another model (which you took it to put it on this c2003)?
      no, look, the story is this: the finisher is on 2003, I have retired it-repaired-tested on a mpc3003 here in the lab, the mounting accessories are the same
      "I'll be back"
