sr970 / mp8000 hole punch skewing
  • morgansterne
    • Oct 2007
    • 83
    I have an issue with mp8000 + sr970 hole punch misalignment. I can't find any info on this here or through the ricoh hotline. The hole punch is aligned if sending to the top finisher proof tray OR if you are stapling. But if you send to the shift tray without stapling, the paper seems to be going in skewed about 10 percent of the time and thus the hole punches are skewed.
    I looked over the finisher for two hours yesterday for some sort of physical block or a spring falling off of a roller bracket, etc., but could not find any such issues. I also cleaned the finisher rollers in the paper path and removed all the chads from the whole punch unit. there's only 35000 copies on the machine so I don't believe any component could be worn down.
    My mp8000 has the current 3.18 finisher firmware. Any help would be greatly appreciated.
    Morgan
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Is the print skewed on the page? If so, look further up stream. Does it do it from all trays? Does it do from the bypass?
    If not, check the exit/turnover section. Check the idlers and the spring loaded guides for proper tension and alignment. They can be bent or mis aligned when clearing jams or by not closing the guides when closing the sections or front doors.
    I'm assuming it works ok face up but not face down exiting or vice versa.
    • morgansterne
      • Oct 2007
      • 83
      solution for skewed hole punches sr970
      updated all finisher firmware and this fixed the problem. Thanks for the suggestions.
      Morgan
