Ricoh Error Code SC672
  • Chaudhary Sher
    • Feb 2019
    • 2
    [Error Code] Ricoh Error Code SC672
    Hi All,
    I need your help, I have a problem with Ricoh MP4500.....
    The code SC672 is not gone. I try my best. I clean RAM more then 30 times, Change Hard Disk, change Printer/Scanner card and the last step i do firmware but it can`t proceed....
    Please help me..... What I do.....
    Thanks in Advance.....
    Regards: Sher.M
  • Chaudhary Sher
    • Feb 2019
    • 2
    Re: Ricoh Error Code SC672
    If this is firmware fault ,
    So can anyone help me how i installed firmware or which type of firmware......
      • 37515
      Call an authorized Ricoh dealer and pay them to send a qualified tech out.
        sounds like you don't know what you are doing.. Hire a tech.
        • vargue
          • Oct 2011
          • 404
          It's not firmware fault.
            • 8165
            Hi All,
            Regards: Sher.M
            30 times!? Is there any contacts left!
            Is the error intermitent or constant
            • djs9164
              • Mar 2018
              • 79
              Can you upload a copy of the maintenance report showing firmware version? When does it happen? Could even be a bad print job. Need more information.
              Sent from my XT1635-01 using Tapatalk
              • fshead
                • 2376
                Hi All,
                Regards: Sher.M
                hmmmmm..I clean RAM more then 30 times,
                the manual says you need to clean RAM 31 TIMES.........
