Mp c6502 sr4090 exit issue!!!!!
  • peakjohn
    • Jun 2017
    • 6
    We have two 6502's next to each other, one runs fine and the other one runs fine on 11x17 and legal but after stapling 8.5x11 the paper exits at a high rate of speed. The copies exit so fast that they hit the copier next to it. We have replaced the exit motor, updated the firmware, and replaced the board. We also swapped the finishers and the problem followed the finisher and by the way the finisher is a SR4090. Thanks for any input.
  • fshead
    • 2376
    Re: Mp c6502 sr4090 exit issue!!!!!
    did you compare dip switches per machines?
    Does it only do it in staple mode?
    • peakjohn
      • Jun 2017
      • 6
      Thanks for your input, we did check the dip switches and it does only happen when stapling.
      • fshead
        • 2376
        maybe state where you are located and someone might have a working unit to sell you.
        I myself would rather pay to make a problem go away especially if it is something i might never see again.
        • fshead
          • 2376
          plus it looks like the SR 4100 will work on that model.
          I am sure wth board,motor and labor spent you are looking at some coin$$$
          • zulufan1
            • Oct 2009
            • 45
            There is a bulletin on this. It has to do with the eject belt getting out of time. Hard to explain without pics.
              post the bulletin!
              • luca72
                • Oct 2017
                • 1774
                sorry stupid observation (seen everything you've changed) ... but the gathering roller?
                "I'll be back"
                • MIKON
                  • Jul 2015
                  • 186
                  hope this helps.
                  • peakjohn
                    • Jun 2017
                    • 6
                    Thanks for posting the bulletin i'll try it and post my results.
