MPC401 - Line on scan & copy from adf only - from glass ok - advice needed please
  • dave w
    • Jun 2015
    • 230
    Advice needed please
    My last job last night was looking at a MPC401 with a line on scans
    On investigating it seems the line is only from the ADF.
    Scan on the glass is fine, Scan & Copy from ADF shows the paper edge as a line.
    If Copy enlarge is set to 120% the line goes.
    Adf rollers cleaned and sensors cleaned.
    Had to leave site due to office closing.
    Need advice on what I do next please
    Thanks in advance
    Dave
  • Polarbear
    • Feb 2012
    • 1070
    Re: MPC401 - Line on scan & copy from adf only - from glass ok - advice needed please
    Sounds like the machine is picking up the edge of the paper and that ends up being printed. Check the settings for the df magnification and erase margins vs the birth certificate.
    Sent from my SM-G950F using Tapatalk
    Press the GREEN button!!
    • dave w
      • Jun 2015
      • 230
      Thanks Polarbear - will try that
      • davel
        • Oct 2011
        • 1104
        DF side registration
        • dave w
          • Jun 2015
          • 230
          Leading edge registration was at 2.0 - birth was 0
          I adj to -0.5 and all ok
          We did a full firmware update not so long ago and possibly the DF adj were affected.
          Many thanks all
          Dave
          • fshead
            • 2376
            if that is on the trail edge you can adj trail edge void.
            I dont remember the exact setting but i think it is sp 6006 and subs
            • fshead
              • 2376
              plus your lead edge might be off,draw some arrows on the lead and trail edge and recheck
              • dave w
                • Jun 2015
                • 230
                Many thanks to all
                Copytechnet is by far the Best place to be.
                  • 37491
                  You have a dirty slit glass. This is the glass that the paper passes over when using the ADF. Could be something stuck to the surface or a spot on dust/lint on the bottom. I have also seen it happen from a scratch of the glass.
                    it looks to be LEF feed in ADF?
                    defect in red circle?
                    what is top left corner.. was it folded?
                    • dave w
                      • Jun 2015
                      • 230
                      was it folded?
                      Yes - it was stapled to the job sheet and i scanned it to my pc ready to post the fault.
                      All sorted now and again MANY THANKS!
                      "Leading edge registration was at 2.0 - birth was 0
                      Many thanks all
                      Dave"
