Ricoh mpc 2003 Fuser unit
  • Dalysdigital
    • Feb 2019
    • 17
    Hi there,
    I have got a local engineer fix my fuser flim and he had accidentally broken the lamps and now he changed with another one and the printing in 12 by 18 is got getting fused.
    images attached kindly help me on this.
    Thank you IMG_20190219_173921.jpg - Google Drive
    IMG_20190219_173956.jpg - Google Drive
    I tried fixing the fuser lamp and it seems shorter of placed incorrectly.
  • fshead
    • 2376
    Re: Ricoh mpc 2003 Fuser unit
    why are you not having "local engineer" finish the job?
    If he is not a copier tech you might want to hire a copier tech...
    I dont go to a dentist when my feet have issues.
    Fusers are tricky and can be dangerous in the wrong hands,bypassing thermo fuses and such.
    The early analogs Sharps i use to work took out many offices by catching fire
    • Dalysdigital
      • Feb 2019
      • 17
      Well he is technically working with Ricoh but his work experience on colour copiers are very less so that why i named him as a local engineer.
      Can you suggest thru the pic if the thermo fuses are smaller because as to me it looks smaller or may be isnt placed right.
      • Gary Bowen
        Bowdog
        • Mar 2008
        • 250
        OK as it is so often asked on this forum WHAT WAS YOUR ORIGINAL PROBLEM? The Fuser Lamps are part of the Fusing Sleeve Assembly and are NOT a stand alone part - the Fusing Sleeve and Lamps are part of the same assembly. How was he able to break the lamps?
        • TonerMunkeh
          Professional Moron
          • 3865
          If I were to guess they tried replacing just the sleeve itself and not the assembly.
          Hit it.
          • Dalysdigital
            • Feb 2019
            • 17
            Well i got a torn fuser sleeve so i called the technician and he bought a new fuser flim/sleeve and repaired that part while he tired fixing in seems like had no clue on how to fix it back on the fuser lamp so it got broken and came the next day with another lamp and all he did was use a wire to make it hold it in the middle. And after it s all done i thought it was perfect for printing A4 and A3 but while trying to print A3+ (12in by 18in) my left portion isnt getting fused about 1.5 cm the colour toner is falling off.
            so what i need is a manual or a good video regarding the fuser unit on dissembling.
              • 37458
              I would suggest that you now replace the entire fusing unit.
              • Dalysdigital
                • Feb 2019
                • 17
                Same here I tried searching for it online and offline but seems like running out of luck.
                  • 37458
                  You need to search by part number. Your profile shows India so assuming 220v that would be D1764010.
                  • fshead
                    • 2376
                    bought a new fuser flim/sleeve..do you know that these work?
                    I TRIED cutting corners buying a chinese knockoff fuser sleeve and it gave me all kinds of headaches and i ended up just buying the danm fuser sleeve.
                    It sounds to me you need to find a "real tech" to look at your machine.
                    sometimes one has to pay for experience..
                    If your engineer is breaking lamps and cant figure poor fusing issues maybe he should not be doing this,
                    Yes you can buy a whole fuser unit but that wont be cheap.
                      • 8142
                      This work practice sounds down right dangerous.
                      Unplug the machine & CALL A QUALIFIED TECH!
                      • guitar9199
                        • Sep 2016
                        • 1100
                        I second this!! Copier fusers aren't something you want to have "Cobbled together"!!! Because of the voltages and temperatures involved, you run the risk of a fire.
                        If you're LUCKY, you'll just burn down the building!! If you're NOT, lives could be lost!! Unplug it, and call a QUALIFIED service technician!!
                        • sandmanmac
                          • 3981
                          Seriously?!!
                          I hope you have a fire extinguisher handy.
                          This is the biggest hack job I think I've ever heard described!
                          You'd best get someone in there NOW and fix it properly, or your problems are bound to be far worse than just a fuser problem
                          • jonhiker
                            • 661
                            I would suggest that you contact the repair company and have them send a qualified repair person.
