Ricoh 2003 Colour Issues & Lines
  • Dalysdigital
    • Feb 2019
    • 17
    [Misc] Ricoh 2003 Colour Issues & Lines
    Hi there,
    My machine has some kind of colour issues, if i photocopy in colour the print has quality but when i print from a computer the colour is light and also so many lines occur on CYAN and Yellow.
    i had Replace drums & Rollers on Cyan but never it had made any difference. The machine has only printed 20,000 pages only.
    I just dont understand why the colour is so light.
    Images attached below would help you guys understand better and also the red colour even on colour photocopying the colour is very light.
  • ridgemill
    • Sep 2017
    • 190
    Re: Ricoh 2003 Colour Issues & Lines
    Worn developer, worn drum, missing the rear drum plate, condensation or dirt on/inside the laser, worn PTR, or poor paper quality; are all the common causes for faint image.
    • Dalysdigital
      • Feb 2019
      • 17
      Thanks for your reply and i want to understand on the missing the rear drum plate, condensation or dirt on/inside the laser, worn PTR. If you can specify with an image since i need to fix this myself.
      and do i need to change the CMYK Developer and Drums and other too
      • TonerMunkeh
        Professional Moron
        • 3865
        Hit it.
        • luca72
          • Oct 2017
          • 1779
          Originally posted by Dalysdigital
          Hi there,
          take out the development groups, look at the magnet, you will see more or less those lines on the magnet (doctor blade clogged) turn the gear of the magnet in the opposite direction 4-5 turns, and then again in the right direction 4 - 5 turns, repeat until the lines disappear ... repeat this procedure for each development group
          "I'll be back"
          • Dalysdigital
            • Feb 2019
            • 17
            Very true so i cant run this machine like a production printer.
            • Dalysdigital
              • Feb 2019
              • 17
              Can i get a video on how to :-P bcoz its quite complex on understanding.
              • JDYAL
                • Sep 2008
                • 187
                What are the counts for the developer? It definitely looks like it needs new developer units. I think the developer for these machines are only good for 120,000 prints and the drums are only good for 60,000.
                • luca72
                  • Oct 2017
                  • 1779
                  sorry, are you a technician? it's a bit complicated to make a video, if you know how replace a pcu & dev you'll know what I'm talking about, but the laser glasses will have cleaned them?
                  "I'll be back"
                  • luca72
                    • Oct 2017
                    • 1779
                    ok, I found this video, it is not the same machine, but the concept is applicable anyway ... look at the time code 0.53> the gear rotated by hand and what is written in the video ... I hope it
                    can help you , have fun
                    YouTube
                    "I'll be back"
                    • fshead
                      • 2376
                      note to "real techs" here he is not a tech and he was the one with the post regarding"
                      Re: Ricoh mpc 2003 Fuser unit ..
                      I would suggest you find a tech to service your color machine.
                      • luca72
                        • Oct 2017
                        • 1779
                        ok, I found this video, it is not the same machine, but the concept is applicable anyway ... look at the time code 0.55> the gear rotated by hand and what is written in the video ... I hope it
                        YouTube
                        "I'll be back"
                        • copier tech
                          • 8144
                          Hi there,
                          Have you cleaned the laser? Inside the front door is a blue cleaning rod, it might simply be some toner dropped on the laser slit glass.
                          • Dalysdigital
                            • Feb 2019
                            • 17
                            YouTube
                            Thanks for the video
                            Tomorrow I'm gonna try
                            And I'm not a certified technician but I watch videos and learn thru utube.
                            • Dalysdigital
                              • Feb 2019
                              • 17
                              That's the first thing I ever did.
                              But seems like that was never a fix.
