Ricoh MP C 4504
  • jrob416
    • May 2011
    • 112
    [Misc] Ricoh MP C 4504
    I have a MP C 4504 that has recently lost its mind. The church it's in had us move machine to allow painters to work behind it. Machine was powered down and moved to middle of room and then powered on. At this point my adventure began. Machine took considerably longer than normal to come ready. No code was given. When machine was ready, print jobs would come out 2 pages at a time. (10 page document would come out in 5 sets of 2 pages). If a door were opened, the screen would display the red outlined box with a flickering image of machine compressed into 1/4" line of pixels. I have formatted HDD, updated firmware, cleaned and re-seated RAM and connectors on main board, control board and user interface. Now when a door is opened, machine stops, but gives no indication on display that anything is wrong. The copier communicates readily with computers on network and scanning is no issue. Thanks in advance for any suggestions.
  • fshead
    • 2376
    Re: Ricoh MP C 4504
    stupid question but did you ck the new outlet for ground and proper voltage.
    I can see a church cutting corners by paying a hobbyist to wire an outlet.
    If you move it back to original location anything different?
    is it on a good surge protector?
    • jrob416
      • May 2011
      • 112
      Re: Ricoh MP C 4504
      The machine stayed plugged to same receptacle and surge protector. Tried without protector, no joy.
        • 37532
        Re: Ricoh MP C 4504
        Did you add an extension cord?
        • guitar9199
          • Sep 2016
          • 1100
          Re: Ricoh MP C 4504
          +1 on this.
          I had an issue with a Sharp "Locking Up" where the customer would have to reboot the device, so after troubleshooting we thought the main controller was shot. Swapped it for a different Sharp copier as a loaner, and within 2 days it started doing the exact same thing!!
          Brought a line tester, and the AC voltage would fluctuate to as high as 120 VAC, but would drop down as low as 113 VAC. Also saw a 6-8% drop in current under a 15 amp load, and 5% under 20 amp.
          Surge protectors are great to help protect against spikes...but they don't do diddly-squat for "Sags".
          Good luck.
          • jrob416
            • May 2011
            • 112
            Re: Ricoh MP C 4504
            Actually, removed an extension chord
            • jrob416
              • May 2011
              • 112
              Re: Ricoh MP C 4504
              Originally posted by guitar9199
              +1 on this.
              Good luck.
              • DRichard
                • May 2008
                • 482
                Re: Ricoh MP C 4504
                You moved the machine to allow painters to work...has the church had any other work done during this time? In particular, was any electrical work done? I am going along with the previously suggested "bad outlet" theory here.
                "Enjoy every sandwich."
                -- Warren Zevon
                • jrob416
                  • May 2011
                  • 112
                  Re: Ricoh MP C 4504
                  No sir. No other work being done.
                  • anothertech
                    • 1771
                    Re: Ricoh MP C 4504
                    What is the volage hot to neutral?, and how many volts from neutral to ground? Is your surge suppressor a line monitor?
                    • keithxxiii
                      Just a tech
                      • Nov 2014
                      • 469
                      Re: Ricoh MP C 4504
                      The MFP must be haunted.
                      May i suggest doing a backup of the NVRAM, then do a clear, test if the problem is still there. Another suggestion if you have a spare SOP, try swapping them.
                      Aye! Cut the crap
                      • jrob416
                        • May 2011
                        • 112
                        Re: Ricoh MP C 4504
                        Tried the NVRAM back-up, restore remedy. No change. Swapped controller board. No good. Looking at BCU now. Thoughts?
                        • fshead
                          • 2376
                          Re: Ricoh MP C 4504
                          regarding how many volts from neutral to ground?
                          arent they the same..0 volts?
                          I MEAN THE NEUTRAL and ground both connect to the same ground bar in sub panel???
                          • sturmtrooper
                            Copier Combobulator
                            • May 2016
                            • 587
                            Re: Ricoh MP C 4504
                            If there is a load on the circuit you should see 1-2v between neutral and ground.
                            • fshead
                              • 2376
                              Re: Ricoh MP C 4504
                              ok..I ve never had to test the voltage between neutral and ground and especially with a load on...
                              I guess that can left to the newbies to do when they are focused on texting with their phone at the same time as testing....
                              That will wake them up..
                              I Still remember the time i have a bad high voltage power pack and went to ck it and got hit wth 6,000 volts..
                              Low amperage but it left a big impression...
