Ricoh 2060 SC821 / SC990
  • tibbs
    • Aug 2008
    • 223
    First this machine showed the SC821 error then the SC990 any ideas. Thanks
  • mikadonovan
    • May 2008
    • 2931
    You can try to boot the machine from an sd boot card P/N B6456090 using the procedure outlined in tech bulletin #091R. If that doesn't work you may be looking at an expensive controller board replacement.
    NEVER ASSUME ANYTHING
    • trc
      • Jan 2007
      • 95
      try changing memory
      • copytech22
        • Dec 2008
        • 33
        Unrecoginized SD Card and FW UG
        990 basically means you need a FW UG
        Insert your SD card which MUST be in the bottom slot. I had the same issue same model. Make sure to move the FW from the SD card using a laptop. Formated the SD using FAT 32 (not a quick format) put FW back on the card and viola. if not you will get different SC Code relating to the machine not being able to read the SD card data or its format is unrecognized
        • copytech22
          • Dec 2008
          • 33
          990 Software error
          The software performs an
          unexpected function and the program cannot continue.
          This is from the Manual
          I would try to FW UG before the more expensive board
          • YHEL23
            • Nov 2008
            • 146
            i agree to copytech22 try to upgrade the firmware first.......
            DYNAMIC OFFICE SOLUTIONS
            • claudioterrible
              no mercy...
              • Oct 2008
              • 96
              how many copies has the drum? chek if you have a corona leak first,chek the symple before go deep
              • copytech22
                • Dec 2008
                • 33
                Yes also Did a PCU rebuild which included the corona wire and grid, but I was also having 220 codes ALL WAS CLEARED UP
                • claudioterrible
                  no mercy...
                  • Oct 2008
                  • 96
                  omar ,trc ,de donde sos capo?
                  • Shadow1
                    • Sep 2008
                    • 1642
                    Format the HDD - SP5832
                    73 DE W5SSJ
                    • FRIDGEMAGNET
                      • Aug 2007
                      • 377
                      The SC821 could be a controller memory problem - try changing that as well.
                      • trc
                        • Jan 2007
                        • 95
                        • Benedict
                          OA techy
                          • Aug 2008
                          • 39
                          OA technician
                          I would go with the drum theory replace if over its yield check corona unit for arching and if you are using compatible drum use original and check that your charge,grid,dev and transfer bias is not out of spec.The AF 2035 had similar issues all the solutions in the manual for the code did not work field techs were pushing yield on the drums not advised.good luck!!!!
