C5502 fuser film asm in C3502
  • tinfox
    • 317
    I thought I read somewhere here that the D144-4272 C5502 asm will work in the C3502, but not vice versa?
  • davel
    • Oct 2011
    • 1107
    Re: C5502 fuser film asm in C3502
    True, different lamps.
    • tinfox
      • 317
      Cool. Thanks. The 55 version is cheaper and I'll only need to stock the one number.
      • fshead
        • 2376
        in the real world i would think you could go from using a 5502 in a 3502 but who know wth these models.
        You can try if it works great..how much cheaper in % are you talking?
        • Zeldaman
          • Mar 2011
          • 946
          • copier tech
            • 8192
            You can use the SPC complete fuser unit cheaper than just the sleeeve.
            • tinfox
              • 317
              Does the SPC unit also fit the c5502/c4502?
              Also, I saw a c3002 today that was intermittently wrinkling the paper. I'm assuming thats from the fuser unit as i didn't see anything else wrong with the machine. The meter was around 290K
              • fshead
                • 2376
                check the metal fins on the transfer roller..
                I had one do that as i too thought fuser 1st
                • anothertech
                  • 1771
                  1+ on the metal fins, hard to spot sometimes.
                  • copier tech
                    • 8192
                    Yes, in The UK we use Fuser Unit 407099 for all MPCxx02
                    • tinfox
                      • 317
                      I went back to the account to check the fins, but there weren't any.
                      • fshead
                        • 2376
                        SO is it confirmed a mpc5502 sleeve D144-4032 will work in a mpc3502?
                        • fshead
                          • 2376
                          i ve swapped out the c430dn fusers for the mpc400 by swapping the 3 loop connector.
                          Is that the same with the spc830 fuser?
                          I Could not find a cheap c830 fuser but have a low meter perfect pull i could use...
