clarification on disabling java
  • luca72
    • Oct 2017
    • 1775
    hello everyone, to disable java sp 5730 from 1 to 0, so far everything is ok, but on other models there is written "20 days" (?), what does it mean? on the SM there is written "DFU" (only for factory) ... someone knows me better to explain what value must be put to be sure to have disabled java? and what does "20 days?"
    Thanks in advance
    "I'll be back"
  • slot
    • Jul 2008
    • 341
    Re: clarification on disabling java
    I have always set the java if not required to 0 and never had any problems but i have seen the 20days message.
    • luca72
      • Oct 2017
      • 1775
      so i ignore the writing 20 days and put it to 0?
      "I'll be back"
      • slot
        • Jul 2008
        • 341
        yep i just normally go to 5730 set from 1 to 0 then copier boots up a lot quicker etc
        • luca72
          • Oct 2017
          • 1775
          yes, thank you for the confirmation, I tried just this morning on a mpc2004 and actually the time of loading is drastically reduced, it was just what I was looking for
          "I'll be back"
          • illude2
            • 30
            Thanks in advance
            The machines that i have seen the 20 days (New IMC series) don't have java by default. It is an option that has to be installed via a sd card.
            • copier tech
              • 8142
              You can also set the screen boot up time from quick to normal, bizarrely normal boots quicker than erm quick!
