MP3350 died when I replaced the drum and blade
  • Blazer1087
    • 195
  • fshead
    • 2376
    Re: MP3350 died when I replaced the drum and blade
    DID you use a vacuum on inside of copier?
    Did you unplug machine before removing fax op.
    • Blazer1087
      • 195
      • fshead
        • 2376
        I ALWAYS unplug all my machines b4 removing anything,fax op,controller,sorter,adf, anything...
        You might have "BRICKED" this machine..
        • Blazer1087
          • 195
          • fshead
            • 2376
            i cant say and i stopped servicing and selling mid range ricoh b/w for over 5 years now so i dont even know that model.Might want to try to get a used parts machine..where are you located?
            • Blazer1087
              • 195
              Yup, looking for a parts machine now. Thanks for the response, appreciate it.
              • copier tech
                • 8143
                Might be worth re-flashing the firmware it may have become corrupt worth a try before replacing parts.
                • fshead
                  • 2376
                  where are you located????
                  • stani
                    • Jan 2013
                    • 49
                    you can try accessing the machine thru web-interface, maybe you can see the error-code
                    • Blazer1087
                      • 195
                      • Blazer1087
                        • 195
                        Seattle area
                        • Blazer1087
                          • 195
                          • fshead
                            • 2376
                            its worth a shot..
                            I can get those models but i am in ny....way too far.............
                            That s what i do when i get a machine that bricks out...
                            I cant see spending 500 to 600 bucks just to revive it...
                            • keithxxiii
                              Just a tech
                              • Nov 2014
                              • 468
                              Print and Scan is an option for this machine that's why it was able to copy. It has HDD so I assume there was an SD card inside that you might have misplaced. Check if you can have this part D383 5050 SD-Card - P/S Unit.
                              Aye! Cut the crap
