MP C3003 optics noise
  • COPIERMAN
    • Jun 2009
    • 559
    When the optics are moving they make a squeal noise. i have been using Plus Guard to put a lite coating on front and rear rails. i t works for a while then starts up again is there something better to use for this problem.
  • Zaxxon
    • 608
    Re: MP C3003 optics noise
    Use the ADF
    Please start you post with brand, model, problem.
    • copier tech
      • 8133
      This has been a known issue for many years.
      See attached pdf.
      METIS Scanner Rail Squeak.pdf
      • zed255
        How'd ya manage that?
        • 1024
        In my experience it only makes noise on the return to home and does not cause image quality issues, so is really an annoyance more than problem.
        Make sure the plastic pads that ride on the rails are clean and only use the slightest hint of light oil on the rails. I actually use ATF and rarely get repeat calls for this.
          I found that the Berretta (SP?) fuser grease for the Ricoh fuser works real well .. HI TEMP and lasts a longer time.
          Are you sure there is no metal>metal contact causing the squeal? That would be paramount to fixing the issue... band-aides are only good for so long.
          • copier tech
            • 8133
            The TOP rails often get missed as they are hidden, so grease 2x front & 2x rear rails.
              • 37422
              You might actually be making maters worse as any lube film will attract dust which will eventually cause squeaking.
              • Coptech
                worker drone
                • 460
                Back in the day... they used to recommend Launa oil as it did not attract dust. It was very thin and very expensive. Pretty much put a drop on and wiped it off with your finger.
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 587
                  Launa oil is what Ricoh puts on them at the factory and is what they say to use on squeeky units. You can buy it from Ricoh VSSA9001 and but it's pricey. Or you can get it online.
                  I have also had this problem on 54 series machines. I imagine that the scanner unit is the same between the two models.
                  Synthetic Lubricating Oil LAUNA#40 20ml made in Japan | eBay
                  Japan Hobby Tool LAUNA #40 Synthetic Lubricating Oil JHT9593 B&H
                  • COPIERMAN
                    • Jun 2009
                    • 559
                    thanks went on ebay and bought oil
