Katun Ricoh Aficio 350 Upper Fixing Rollers
  • Fierhawk
    • Jul 2025
    I was wondering if anyone has had problems with Ricoh Aficio 350 upper fixing rollers from Katun where the paper misfeeds only on the backside of the copy? Any help appreciated, thank you.
    • 23007
    Stay away from them. The length isn't quite right, so one or the other bearing falls out of the frame. They tend to pick up toner, and don't last as long as the OEM. =^..^=
    • Fierhawk
      • Jul 2025
      katun upper fuser rollers
      i don't have problem with rollers from other sources just katun and with katun it's only ricoh copiers.
