mp2000 vs mp2501 pcdu parts compatibility (?)
  • luca72
    • Oct 2017
    • 1791
    hello everyone, since it is becoming annoying to handle almost equal parts for two very similar machines, I wanted to ask you:
    someone tried to check in the field if the parts are interchangeable between one and the other, despite the different codes (?) (developer, td sensor pin-layout, cleaning blade, etc)
    I have noticed for example that the cleaning blade with different code looking at it well changes that on the surface it has like micro-wrinkles that the mp2000 has not ... the rest only changes the back flange and some plastic pieces.
    once we took a used 2501 which had previously been replaced by the toner engine with the mp2000, and the 2501 worked very well with the mp2000 toner, this made me doubt that the developer is the same ... in substance...
    what do you think .. commercial strategy to sell you more spare parts than you would need to stock up? .. or they are really incompatible.
    P.S. surely a discussion of this topic has already been done, but I haven't found it
    kind regards.
    "I'll be back"
