mpc8002 doc feeder issue
  • digicor
    • Jul 2008
    • 1159
    I have a doc feeder on a MPC8002 that will pull multiple pages only when its loaded with 2-3-4 sheets, if i load it up with 60-70-80 it runs just fine..??
    i of coarse changed the sep roller,white mag clutch, and cleaned the little mylar rubber combo pad any one have this issue?
    • 37533
    Re: mpc8002 doc feeder issue
    By white mag clutch do you mean the torque limiter that the separation roller mounts onto? If not, replace it.
    • digicor
      • Jul 2008
      • 1159
      yes i meant the torque limiter, but im going to re place it again, it could be defective
      • Athlontini
        • Jun 2012
        • 269
        See if there's a firmware update for that SPDF. They just came out with one for the Metis series that addresses separation issues (multifeeding, sep sensor jams). Also a good idea to replace the guide with the rubber pad on it.
        • digicor
          • Jul 2008
          • 1159
          okay i replaced the guide with the rubber pad,the torque limiter, and the reverse roller again all OEM
          worked all day yesterday, just got the call its still pulling 2 together when theres only 4 pages, at 7 pages it does not! ????
          could firmware be the issue?????
          • digicor
            • Jul 2008
            • 1159
            do any of yo have FM for this particular issue i can get from you?
            • digicor
              • Jul 2008
              • 1159
              I did notice a small "rut" in the lifting tray, right where the feed tire grabs the paper, but they all seem to have this little shiny rut right there,
              sorry im drawing at straws here
              im having the client put a piece of tape over it...
