Mp5002 streaks
  • mrfuser
    • 1622
    Mp5002 streaks
    Anyone see see this type of light background streaks on a bw mp5002? Replaced drum and cleaned pcu as well as laser glass and vacuumed out transfer assembly.
    • 37550
    Re: Mp5002 streaks
    If the development roller is coated follow the instructions in the attached bulletin. If after cleaning you observe scratches running the length of the roller. replace the roller. You may have to order the entire development unit. BE SURE TO USE ONLY GENUINE RICOH OR N.A. TRADING TONER AND DEVELOPER.
    The problem could also be a bad charge roller.
    007-rfg032790.pdf
    • Zeldaman
      • Mar 2011
      • 946
      • JayPaul
        • Oct 2012
        • 305
        Re: Mp5002 streaks
        Is there a way I can enlarge that picture it comes up really small if I try looking at it?
        I would probably try another charge roller, clean out dev unit, clean mag roller fully, re dev and go from there.
        I have once rebuilt pcu and dev and kept getting really bad grey backgrounding, turns out the charge roller was bad and had to put another new one in and problem went away.
        • mrfuser
          • 1622
          Re: Mp5002 streaks
          Will a dv unit from an mp4001 work in a mp5002?
          • COPIERMAN
            • Jun 2009
            • 559
            Re: Mp5002 streaks
            i don't know if this helps but i just ran into a problem with back ground on the MP3353. We rebuild our units over and over but never replace charge cleaning roller. We just started having background issues after rebuilds about a 1000 copies and background. I brought one back in and started to trouble shooting. Replace everything but still had problem. I realize only item i had not replace was the charge clean roller. Swap and no more background.
            • HitMan
              • Aug 2015
              • 170
              Re: Mp5002 streaks
              Yes it's the same developer and I think it's the same dev unit
              Sent from my SM-G930F using Tapatalk
              • FrohnB
                • Jul 2017
                • 1919
                Re: Mp5002 streaks
                When you replaced drum did you replace the cleaning blade also? If so, did you put lube powder on blade? I also like to take the lube powder and apply it to the drum (about 2 inches wide) and give the drum a full rotation (while making sure to clean any residual powder from charge roller). Just wondering if the cleaning blade may have "Flipped".?
                Secondly, I have seen where the charge roller stalls (doesn't spin freely), and can give lines like this. Usually just take it out and clean the bushings it sits in, and clean the charge roller shaft. (also check that the two contact tabs for the charge roller aren't bent or dirty.
                Thirdly, as others have suggested, Clean or replace the development roller. The lines seem to show up in a uniform fashion. Roll that piece of paper up and match the marks to see what size roller could be causing it.
                And yes MP 4001 DV unit works in MP 5002.
                Omertà
                • mrfuser
                  • 1622
                  Re: Mp5002 streaks
                  Replaced entire pcu with dv assembly and transfer belt assembly. Same result, streaks!
                  • FrohnB
                    • Jul 2017
                    • 1919
                    Re: Mp5002 streaks
                    Only other thing then is the fuser!
                    Is that paper being fed LEF or SEF? Short edge feed looks like a smaller diameter roller (mag or charge).
                    Long edge feed would be a different story.
                    Either way, on to the Fuser, mrfuser!
                    Omertà
                    • HitMan
                      • Aug 2015
                      • 170
                      Re: Mp5002 streaks
                      If the fuser Web is still attached how about removing it to see if you get a different result? Also there's a fuser cleaning roller that might need cleaned inside the front of the fuser
                      • HitMan
                        • Aug 2015
                        • 170
                        Re: Mp5002 streaks
                        Then again it could be something inside the transfer belt the diameter of those marks looks like it might match up with one of the rollers inside the unit under the belt
                        • mrfuser
                          • 1622
                          Re: Mp5002 streaks
                          Yeah thought about fuser also and tore it apart and all looks good. Streaks almost look like toner dragged across page lef direction.
                            • 37550
                            Re: Mp5002 streaks
                            Yes. Same part number D0092301.
                            • omorales
                              • Mar 2015
                              • 86
                              Re: Mp5002 streaks
                              Clean ,Registration Roller
