Mp5002 streaks
  • mrfuser
    • 1617
    #16
    • HitMan
      • Aug 2015
      • 170
      #17
      Re: Mp5002 streaks
      Laser and led array that discharges the drum
      Sent from my SM-G930F using Tapatalk
      • HitMan
        • Aug 2015
        • 170
        #18
        Re: Mp5002 streaks
        I would say that the led array that's meant to discharge the drum has maybe gone faulty. Cant see the laser causing that but have seem the discharge lamps cause print quality issues
        • JayPaul
          • Oct 2012
          • 305
          #19
          Re: Mp5002 streaks
          Quenching lamps I think they are called?
          I have seen on mp2550 a couple of years ago they went faulty and it kept causing every page to be gritty all over, one to remember as have never had any other problems involving quenching lamps before.
          • HitMan
            • Aug 2015
            • 170
            #20
            Re: Mp5002 streaks
            Yeah that's them couldn't think of the name lol
            • mrfuser
              • 1617
              #21
              Re: Mp5002 streaks
              Seems also that maybe the machine is not rotating the cleaning web. Any ideas on this?
              • HitMan
                • Aug 2015
                • 170
                #22
                Re: Mp5002 streaks
                Originally posted by HitMan
                If the fuser Web is still attached how about removing it to see if you get a different result? Also there's a fuser cleaning roller that might need cleaned inside the front of the fuser
                I already mentioned removing the web unit to test
                • HitMan
                  • Aug 2015
                  • 170
                  #23
                  Re: Mp5002 streaks
                  Also you can remove the web completely and the machine will still work with no problems
                  • mrfuser
                    • 1617
                    #24
                    Re: Mp5002 streaks
                    Yes I did try to remove web completely and swapped fuser. Still streaks
                      • 37495
                      #25
                      Re: Mp5002 streaks
                      Measure the spacing between the streaks. That is the diameter of the source.
                      • HitMan
                        • Aug 2015
                        • 170
                        #26
                        Re: Mp5002 streaks
                        My bad
                        • HitMan
                          • Aug 2015
                          • 170
                          #27
                          Re: Mp5002 streaks
                          Well the only thing you can do is jam the machine. You can open the right hand door when a page is going up the vertical feed try and stop it at the drum to see if the marks appear there and then try stop it at the fuser. I know you tried different units but maybe this will help indicate where the fault is coming from?
                          • mrfuser
                            • 1617
                            #28
                              • 37495
                              #29
                              Re: Mp5002 streaks
                              Looking at the parts catalog I would say it is mounted to the frame stay with double sided tape. You can remove the entire stay assembly with 2 screws at the front, there is a tab that goes into a slot in the back frame when putting back in.
                              • keithxxiii
                                Just a tech
                                • Nov 2014
                                • 469
                                #30
                                Re: Mp5002 streaks
                                Hi,
                                I had this problem in MP3353, new drum, charge roller, charge cleaner, developer, fuser...etc PM parts. Since the machine is not frequently serviced, the seal covering the toner recycling unit is bent and out of position causing it to dump unwanted toner.
                                Please check if you have the same deformed seal.
                                Aye! Cut the crap
