MP C2551 "Cannot install this software" after installing PostScript3 SD Card
  • rr8086
    • Mar 2019
    • 13
    Hello. I have bought off of eBay a PostScript3 SD Card for my MP C2551. My photocopier used to have a Java extended feature, which I uninstalled before proceeding to remove the Java SD card and install the PostScript 3 SD Card I received from eBay.
    When I turn on the machine, I now receive an error: "Cannot install this software. This software has already been installed to another machine". This annoying message keeps blinking. The strange thing is that PostScript3 seems to work. In fact, I can see it in the configuration page of the printer and there seems not to be any issues with it.
    I would like to stress that, if I uninstall the PostScript3 SD Card, the message immediately goes away when I turn on again the MPC2551. Can you please suggest me what to do? Shall I return the item to the eBay seller? Maybe the SD Card is corrupt? Possibly there is some other stuff that was merged into this SD Card and this is why the printer complains? Any way to reset this?
    Thanks a lot.
    • 37478
    Re: MP C2551 "Cannot install this software" after installing PostScript3 SD Card
    As the error message says, "This software has already been installed to another machine" and it was not properly uninstalled. Something you should expect when you purchase copier SD cards from ebay. There are a couple of threads that tell you what you need to do in order to make the SD card usable. They have to do with files that are written to the card when it is first installed. Do some searching.
    • copier tech
      • 8142
      Thanks a lot.
      Was this card new?
      What type is the postscript card?
      Can you print with the card removed?
      • rr8086
        • Mar 2019
        • 13
        Hi slimslob, I appreciate your message. Can you please give me a clue what to look for? Sorry, but I am not familiar with this issue and I don't know what to look for. A search for the error message yelded no instructions on which files to remove in order to have the card working. Thanks.
        • rr8086
          • Mar 2019
          • 13
          Was this card new?
          Hello there! Thanks for your message. The SD Card is a Type C2551 PostScript card. I can print perfectly, there is only this annoying message blinking in the left-bottom corner of the copier's screen. I do not see any issue with the PostScript support itself: configuration page is correctly printed, I can print in PostScript from my PC... The error message is the only issue. I suppose some other stuff is on the SD Card, but I do not know what to look for and what to delete, so that my MPC 2051 stops complaining...
          • copier tech
            • 8142
            You don't need a postscript card to print from a PC, like I said take the card out can you still print?
            If you can is the card actually needed!?
            • COPIERMAN
              • Jun 2009
              • 559
              unless you buy new this message will appear. I just let customer know before buying that message will appear for a used card and that printing will work just fine. If they don't like this then I will let them know what a new one will cost this amount and that you will have to pay for it. Most of the time they will be ok cause it is a lot less then what a new one will cost them.
              • rr8086
                • Mar 2019
                • 13
                Hi. I bought the card to print with my Mac. No issue there either. The card is not new, it was used and, most probably, as slimslob says, it was not properly uninstalled. Should I delete something in the SD Card to reset it to its original state?
                • rr8086
                  • Mar 2019
                  • 13
                  Hi Copierman. Your approach is fair, however, I was not told about this issue, or I might have had a second thought... I think this is a breach of eBay's policy...
                  • COPIERMAN
                    • Jun 2009
                    • 559
                    It was tied to old copier by serial number and that is what different. I have bought many of them they work just find. it just has that message to let you know came from another copier that has save my customer money. When you bought did it say new or use. If new then yes that's a problem.
                      • 37478
                      You might try the last reply on this thread. http://www.copytechnet.com/forums/ri...28=#post522774
                      • fshead
                        • 2376
                        i know what the issue is as i have bought used ps3 cards for both the mpc2050 series and the mpc2551..
                        But why not contact from your seller?
                          • 37478
                          Not always an option with ebay.
                          • rr8086
                            • Mar 2019
                            • 13
                            Thank you, slimslob. I will give it a try and let you know.
                            • rr8086
                              • Mar 2019
                              • 13
                              Indeed. Seller from the USA, speaking only Spanish (which I don't speak), pretending it's OK that I get an error message, reportedly as another buyer had the same problem and did not complain. Unfortunately with eBay it is often hit and miss w/ sellers, even if they have a 100% positive feedback.
